Author Topic: Interior light doesn't turn off once the door's closed.  (Read 669 times)
Offline Jack3559
Also... sunroof doesn't work.
Could this be fuse or wiring problems?
I'd like that as it'd be cheap.
(Other than that... the car's fantastic! I'm chuffed.)
Offline audicab26
Re: Interior light doesn't turn off once the door's closed.
« Reply #1 on: 08 August 2010, 15:16 »
Hi Jack,
Re the sunroof - the quick way to check if it is a fuse is to see if the airbag warning light comes on when you turn on the ignition (above the light switch) - if that is not illuminating it will be the fuse as they share the same fuse.
Re the interior light - it should stay on for a few minutes then turn itself off - it does not go out instantly. If it is not that it will be a dodgy switch - nothing serious. I used to leave it switched off as I carried the dogs in the boot and would leave the tailgate or doors open when we stopped.
I had the loom in the o/s/r door replaced recently - so that would be the first place to check
Really glad you like the car - have had a lot of interest in it but I am really pleased it is local.
All the best,
Derek
« Last Edit: 08 August 2010, 20:25 by audicab26 »
Offline Jack3559
« Reply #2 on: 08 August 2010, 19:31 »
Cheers Derek, you're a genius!
I'll go out and check it now...
