Author Topic: Is this normal? Rear Bumper Plastic very wavy around Number Plate area.  (Read 15101 times)
Offline Snoopy
  • Moderator
  • Geoff.
If you push on it, you notice how thin and flexy it is? Im guessing if you push and drill (creating heat) it in theory may distort.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline am1w
... and that is what has happenned, I feel. You can see the strees lines on either side of the plate, equally distributed.
I think we must be the only ones with this problem.
Offline Snoopy
  • Moderator
  • Geoff.
Probably as most dealers stick the plates on.
Mk6 GTI  &  Mk1 GTI
Offline am1w
Here is the picture again.
The circles are waviness in the plastic and the 'line' is the stress line. It is exactly the same on the other side.
Offline am1w
BTW Snoops: The rear diffuser is painted and ready for fitting. The Honda dealer will do for me. Still have not seen it!
Offline Snoopy
  • Moderator
  • Geoff.
If you look at mine on page 3 its the same.  :undecided:
Mk6 GTI  &  Mk1 GTI
Offline am1w
Do you also have the stress line/crease?
Offline Snoopy
  • Moderator
  • Geoff.
My 3rd photo shows how the image is distorted best. Its more a wavy to behind the number plate.
Mk6 GTI  &  Mk1 GTI
Offline am1w
Mine is flat as a pancake behind the number plate. The two depressions and crease lines are outside the number plate area. :sad: :sick: :cry:
Offline am1w
At long last they have agreed to do a localised repair. It won't be 100% perfect, but it will be much better than it is. Will cost £250 according to them. VW to pay. :rolleyes:
Anyway, I am seeing a guy on the 24th who will attempt to improve it with heat etc. But I'll still give it to the VW Body shop. At least they will work on it with a slightly better 'canvas'.
