Author Topic: Dash lights illuminate when key is in ignition  (Read 847 times)
Offline Goonie
« on: 01 August 2010, 13:49 »
I changed the ignition switch the other day now the whole dash & number plate lights are on when the
key is in the ignition.
Any help on what has happened would be appreciated.
Re: Dash lights illuminate when key is in ignition
« Reply #1 on: 02 August 2010, 09:37 »
cant think of any reason why an ign switch swap would have done this, i think you may have some damaged wiringbehind the dash. there is nothing on the ign switch which is connected to the dash lighting, so it sounds like a wire short has happened inside the dash, or a previous owner wired it up like that to be like a MK4 Golf.
Offline Goonie
« Reply #2 on: 02 August 2010, 19:20 »
That is what i thought i had done some damage to wires by the switch.
Your reply knocked me brain into action and remembered that i saw the wires to the glovebox light were loose.
Before i bought the car there was a break in and the glovebox & radio had been damaged/stolen.
Had a look today and they were touching. I guessed they are for the light in glovebox cos there isn't one there.
It has sorted it out now.
So thanks for your help!
« Reply #3 on: 03 August 2010, 09:40 »
glad it was an easy fix, sometimes these electrics can send you round the bend!
Offline Goonie
« Reply #4 on: 03 August 2010, 23:59 »
I'm glad too. Its never that easy.
Next on list got to fix drivers window, replace central locking unit
and a new aerial.
