Author Topic: problem?  (Read 854 times)
Offline Live in Hope
problem?
« on: 27 July 2010, 12:05 »
HI Guys,
When i start my 8v mk3 it sometimes for a split second acts like the battery is flat and a micro chirp from the alarm and my clock milage and everything blank and reset? but car then starts fine! but i dont want to wait till it wont start.
I fitted a new starter motor about 5-6 months ago when the old one just completely died :sad:
Im guessing this is a bad earth? is there a favourable place to start? bit of a novice :huh:
Thanks in advance for any help!
Re: problem?
« Reply #1 on: 27 July 2010, 12:06 »
Is the battery ok, might be worth getting it tested.
Offline Len
Re: problem?
« Reply #2 on: 27 July 2010, 13:03 »
Yes it does sound like a bad earth.
First one to check is from the starter to the engine/gearbox, not sure exactly where that is located sorry!
Also check the battery terminal connections.
www.sas.org.uk
www.the-ace.org.uk
Re: problem?
« Reply #3 on: 29 July 2010, 22:25 »
Cheers for that :smiley: will be having a look tomorrow.
