Author Topic: HELP! NOISY KNOCKING NOISE!  (Read 4369 times)
Offline tinman
Re:HELP! NOISY KNOCKING NOISE!
« Reply #10 on: 26 August 2003, 18:29 »
Not so sure about chain.
If it is, listen to it when it idles and listen out for the noise of a chain. It will be very distinct noise. If you can hear it then there is slack. If not - may not be chain. A tight chain should be almost silent. (or at least drowned out).
If its tappets, i always thought that it didn't go "knock" as so much as "tap".
Sounds more like something more serious has gone. But if you have the time it won't cost much to find out.
Regards,
Tinman
golfvr6
« Reply #11 on: 26 August 2003, 22:59 »
I agree , i think the knocking noise is bottom end engine bearings. New engine needed or engine rebuild.
