Author Topic: Buzzing noise on Vr6 ????  (Read 4991 times)
Offline Burnsy
Re: Buzzing noise on Vr6 ????
« Reply #10 on: 11 January 2005, 09:48 »
Well if those wires are to the water pump then it could be coming from there because if i un screw it whilst its making the noise the noise goes
Offline bolland
  • www.vwsport. co.uk
« Reply #11 on: 11 January 2005, 11:02 »
That wire connector feeds loads of things, well i suppose that much is obvious  :laugh:
The water pump is supposed to buzz when you turn the ignition on, it then goes off when you start the car.
I would look closer at it.
Offline Burnsy
« Reply #12 on: 11 January 2005, 23:35 »
So all Vr6'S make the buzzing noise when the ignition is on ?
ridgers
« Reply #13 on: 11 January 2005, 23:52 »
If you look like bolland said to the left of the connector there is a water pump, place your finger on it and see if you can feel it when you hear the buzzing.
Also I wouldnt keep disconnecting that connector with the ignition on as you may knacker the ECU with a power spike.
Your car hasnt got the coil which is what overseer suggests  as as you can clearly from your pic the HT leads coming from the coil pack.
