Author Topic: Dismantling 16v distributor  (Read 2089 times)
Offline Diamond Hell
  • Opinions я Us
Re: Dismantling 16v distributor
« Reply #10 on: 24 July 2010, 07:47 »
It won't move because you're not using the right tools.
Get it in a vice, as suggested, to hold it still
You need a punch, not a drill bit.
A drill bit has a pointed tip, which will splay open the end you're trying to punch out.  A punch has a flat end that will knock out this pin.
If it won't shift with a correctly sized punch then you need a bigger hammer.
Offline Simeon
« Reply #11 on: 24 July 2010, 10:09 »
Presumably DH he is using the drill bit upside down so effectively making it a punch, but yes, if it won't shift you need a bigger hammer
