Author Topic: Engine Clean  (Read 4636 times)
Offline Adam
Re: Engine Clean
« Reply #10 on: 21 July 2010, 20:09 »
I would say its a bit of a mess in there at 112k. Take off the clip and have a look in there with the valve in situ. I would be inclined to remove the whole system including the intercooler to give it a good flush, its all not that hard to do. Mine was filthy after 80k.
Oh also removing the vac pipe/deleting the EGR gives a slight MPG/performance increase.
Down Hill From Here.
Offline jonesltd
  • MK7 R
Re: Engine Clean
« Reply #11 on: 21 July 2010, 20:21 »
ok will do it at some point this summer as only having a day off aint enough time really
If you cant find it......Grind it
Offline Adam
Re: Engine Clean
« Reply #12 on: 21 July 2010, 20:27 »
As per forum tradition take lots of pictures :afro:
You might as well take off your manifold just to make sure you have de gunked out the whole system.
Offline richandhazel
Re: Engine Clean
« Reply #13 on: 22 July 2010, 10:58 »
I cleaned mine at around 160K and it was very heavily gunged up. I also removed the inlet manifold and cleaned the whole lot up.
Here is a useful article on it:-
http://www.tdiclub.com/TDIFAQ/TDiFAQ-7.html#g
Following that I carried out a procedure in VAGCOM to stop the EGR. So instead of physically removing it or replacing it I have used the software to stop it. Procedure is here:-
http://www.tdiclub.com/TDIFAQ/TDiFAQ-7.html#j
I now have 210K on the clock and it is fine :smiley:
Re: Engine Clean
« Reply #14 on: 22 July 2010, 11:01 »
There are a lot of other useful articles on the that site. Well worth a read:-
http://www.tdiclub.com/TDIFAQ/index.html
Offline jonesltd
  • MK7 R
Re: Engine Clean
« Reply #15 on: 22 July 2010, 11:01 »
Thank you  :smiley:
