Author Topic: Wheel bearing help  (Read 4005 times)
Re: Wheel bearing help
« Reply #10 on: 21 July 2010, 23:50 »
Wood... Get a branch, cut it out, smack the wheel bearing out.... Worked for me as woods softer then metal, so no fook ups on the hub side. New bearing just needed a soft tap with rubber mallet and went in willingly, circlip on and wollah, redneck style.
Yeah righto  :laugh:
Offline golf-sib
  • Турботазик
« Reply #11 on: 21 July 2010, 23:52 »
Yeah righto  :laugh:
I'm being serious, its what I did on my 6n and its still going till this day, can't beat redneck mechanics especially with the aid of a father encouraging you that its a good idea whilst sober  :shocked:  :grin:
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
« Reply #12 on: 21 July 2010, 23:56 »
I guess you were lucky, never done one yet that has not needed pressing out.
Offline golf-sib
  • Турботазик
« Reply #13 on: 22 July 2010, 00:09 »
The bearing had collapsed so I'm not sure if that makes a difference, but due to the density differnce the hub was not damaged or marked, it did 30,000 miles on the new bearing I put on before I changed cars (I imagine its still ongoing) .
Only thing is, when a wheel bearing is on its way out, what's the noise it makes? As I cannot remember what it sounded like, I remember when it collapesed and the vibration on the way home (happened about 1 mile away on the way home). As the golf is very squeky on the passengers front wheel, I have ruled out calipers/brakes and the supension. Can't blame it on bushes as they in a good state still, CV boots are all fine, so my assumption is ball joint or wheel bearing, it started as a minor squeks here and there, now it squeks away non stop even at 30mph.
1.8T AGU..
R135
  24
« Reply #14 on: 22 July 2010, 10:08 »
you did well yo get it in with just a mallet without damage, if they dont go in square they dont like it.  fair play to you :)
if it was me though bearing carrier off -> garage.   i am planning to get myself a press one of these days, but i need to make some room first
Offline AudiA8Quattro
« Reply #15 on: 22 July 2010, 18:32 »
You are welcome to use my press if needed john
Offline danny_p
« Reply #16 on: 22 July 2010, 18:45 »
i allways find getting the old ones out is the issue.   i has a 20T hydralic press and quite often see round about 15T of pressure indicated before they move.
i depending on situation, mood and bearing in question sometimes i tap them in sometimes i press them in
all the VW's have gone bar 1.
« Reply #17 on: 23 July 2010, 09:27 »
are you a local to bracknell then chap? I shall keep you in mind if you are cheers :)
« Reply #18 on: 24 July 2010, 23:17 »
Yes mate, i'm in blackwater, camberley.
You are welcome to use it if you need a press  :smiley:
« Reply #19 on: 26 July 2010, 09:47 »
awesome cheers. hopefully I wont need to but I have a set of VAG bearings if I do  :cool:
