Author Topic: Revo Immobilizer defeat  (Read 3065 times)
Offline Dan_GTi8v
Re: Revo Immobilizer defeat
« Reply #10 on: 20 July 2010, 12:11 »
Fingers crossed I may have a defeated and mapped ecu available to me just waiting for a price, though im sure it will be a good one :)
the mk4 has it built into the clocks.
Does this mean I need to get the clocks from a mk4 as well?
« Reply #11 on: 20 July 2010, 13:54 »
only if you want the immobiliser to work, if you get it defeated then you don't need em :)
Offline Dan_GTi8v
« Reply #12 on: 20 July 2010, 14:20 »
ah ok I just thought if it plugged into the clocks rather than a seperate box it may be a different connection or something. So it just plugs in where the mk3 one was? (I dont have the aum loom yet so havn't looked at it)
« Reply #13 on: 20 July 2010, 14:30 »
the ecu has a diagnostic connection to the clocks, which is how the immob unit communicates to the ecu. this wire (pin 43) you would just run direct to your diagnostics port so you can check fault codes etc. you wont need the mk3 immob unit anymore if fitted either :)
few other wires to the dash from the ecu but nothing you need to worry about :)
Offline Dan_GTi8v
« Reply #14 on: 20 July 2010, 14:49 »
I have an aftermarket immob fitted, will this be affected by it?
Is there anywhere I can see wiring diagrams for the aum and agg looms to see how I can splice them together? or better yet a guide or something to doing it?
Also I'll be wanting to get a cat 1 alarm fitted at some point, will the conversion complicate things much?
People were not wrong by saying getting the engine in is the easy part lol
cheers
« Last Edit: 20 July 2010, 14:51 by Dan_GTi8v »
« Reply #15 on: 20 July 2010, 15:02 »
the aftermarket immob system it depends how it was wired in, usually they tend to be spliced to the dash side of the wiring, so if you're lucky changing the loom would have no effect on the function of the immobiliser. if it is spliced into some of the engine loom wires if you make a careful note of which ones it should be easy to splice it back into the conversion loom :)
with the alarm as long as the engine is in and running it wont make any difference to the alarm fitter :)
as for diagrams, you ask and you get:
http://vwtech.no-ip.info/downloads/g3aggecu.pdf
http://vwtech.no-ip.info/downloads/g4aumauqecu.pdf
Offline Dan_GTi8v
« Reply #16 on: 20 July 2010, 15:36 »
cheers mate :)
