Author Topic: IS this normal? (Engine misfire Q?)  (Read 6307 times)
Offline Hartside
Re: IS this normal? (Engine misfire Q?)
« Reply #20 on: 03 August 2010, 08:05 »
Quote
No engine problems on mine runs like a dream
Only problem with yours mate is that it sounds like a skeleton having a w@nk in a biscuit tin!  :laugh:
I'm probably making more of the very slight hesitation than it actually is. I doubt my wife would even notice it if she drove it, it's just that I pick these sort of things up too easily. After a couple of miles it's gone.
« Last Edit: 03 August 2010, 08:11 by Hartside »
Carbon Grey 5dr GTI
Offline Steve30
  • Ed30 .
« Reply #21 on: 03 August 2010, 08:55 »
Quote
Hartside do one mate get outa here :laugh:
Tiguan quicker than the Golf
Offline jdjd
« Reply #22 on: 03 August 2010, 17:25 »
Any missfire will be logged on the ecu. Just pull up a report.
Offline Hartside
« Reply #23 on: 03 August 2010, 18:34 »
Not a misfire, just very very slight hesitation. I'm wondering if it's not enough throttle and I'm just at the point of the throttle open/close and as the engine is cold it's more pronounced. I'm assuming the throttle is drive by wire and the system works from a control signal.
Carbon Grey 5dr GTI
Offline R32UK
« Reply #24 on: 03 August 2010, 18:47 »
could be a sparkplug problem!!  :smiley:
Offline Hartside
« Reply #25 on: 03 August 2010, 19:09 »
Aye, was just reading your post and wondering the same thing! Is it a problem batch of spark plugs, or are they saying it a problem with engine or ignition circuit?
Carbon Grey 5dr GTI
Offline R32UK
« Reply #26 on: 03 August 2010, 20:11 »
they just said it wasnt fueling properly.. on further inspection the plugs had a wierd coating/residue on them. usually found if dodgey fuel has been used. one of the plugs was even bent and incorrect distance from the spark bit (excuse my technical jarggon) :grin:
Offline The Danno
« Reply #27 on: 04 August 2010, 12:03 »
I have this on my Golf R. First thing in the morning, just a slight hesitation between gears. Feels like the engine dies a bit, I learch forwards a bit in the car and then the power comes back. Only happens when cold usually in the same place just up the road on the way to work. I'm not that worried about it. It's only happened 2 or 3 times, usually when I lift off at a certain rev to change gear.
Offline MAW73
  • Used to like Golfs :-)
« Reply #28 on: 04 August 2010, 14:53 »
Quote
Hartside, that's a great saying above. I've never heard of that one. People at work must think I'm mad, I've been sitting here at my desk laughing out loud :laugh:
2014 BMW F20 M135i, Auto
Offline Hartside
« Reply #29 on: 04 August 2010, 22:17 »
Quote
Pleased you like it - Couldn't resist getting one back on the GTD guys  :laugh:
Carbon Grey 5dr GTI
