Author Topic: g60 top mounts ???  (Read 3815 times)
VeeDubGTI16v
Re: g60 top mounts ???
« Reply #10 on: 14 July 2010, 08:36 »
you want mk3 vr6 ones anyway, a much better design!
« Reply #11 on: 14 July 2010, 09:17 »
thats because early MK3 4 stud models also use G60 top mounts. they arn't really G60 mounts, they're Passat ones. the givaway is the part number 357 = passat
veedub: MK3 VR6 top mounts are the same as all MK3 GTI top mounts, and also they're fitted to late 4 stud models too.  The reason for the myth 'VR6 ones are stronger' is because they were fitted to the Corrado VR6, the 4 pot rados used the G60 top mount setup.
if you want to use the MK3 GTI top mounts on MK2 springs you need the early MK3 GTI top spring plate, part number 1H0 412 341. you also need the threaded bush part number 1H0 412 365 A.  the top retaining cup is different part number 357 412 319 B, but when i test fitted em my mk2 ones seemed to fit alright?  need a new top nut too, part number N   105 352 01
edit: again the MK3 GTI top mounts are actually passat, part number for the mount is 357 412 331 A :)
« Last Edit: 14 July 2010, 09:26 by rubjonny »
VeeDubGTI16v
« Reply #12 on: 14 July 2010, 11:21 »
ah i didn't know that, i suppose the mk3 topmount bushes are priced the same then anyway.
its just such a good feeling throwing the slotted nut in the bin  :grin:
« Reply #13 on: 14 July 2010, 11:36 »
heh yeah :)
did the same upgrade on my mk2 a while ago and its noticably better than the G60 ones i took off. the MK3 4stud widetrack setup is nice as well :cool:
not like the G60 ones are poor though, as long as you get good lemforder ones. the febi ones are hit n miss.
edit: oh and you can somtimes get a good price for the lemforder stuff on ebay, do a search for 'lemforder' in the vw parts section, got mine nice n cheap that way. i had to go to vag for the spring plates and threaded bushes though, but wernt expensive. the annoying thing is i spent ages at the scrappy trying to get the mk3 retaining plates as had been told mk2 ones wouldn't fit, but then when i got home to try they seemed fine to me. I still put the mk3 retaining plates on since I worked so hard to get em  :grin:
« Last Edit: 14 July 2010, 11:38 by rubjonny »
Offline Cory
« Reply #14 on: 15 July 2010, 16:15 »
cheers for all the help guys.  does anyone know a part number for the bearings aswell?
« Reply #15 on: 15 July 2010, 16:29 »
top mount is 357 412 331 A, bearing is 1J0 412 249 :)
