Author Topic: fault code 00589???  (Read 14348 times)
Offline Rhyso
Re: fault code 00589???
« Reply #10 on: 14 July 2010, 12:07 »
Is it the orange one under the seat yeh?
Mine was yellow but if there's only one plug then that should be it  :smiley:
Offline mattGTI20
  • mattGTI20
« Reply #11 on: 14 July 2010, 12:13 »
just been out there its yellow and pink just pulled the plug out gave it a clean then reset it but its still coming back on so what now??
Offline Rhyso
« Reply #12 on: 14 July 2010, 12:14 »
I'd pop to your local dealer and order a replacement loom.  At this stage its far cheaper than forking out for a new airbag!
Offline mattGTI20
  • mattGTI20
« Reply #13 on: 14 July 2010, 12:17 »
would you no how difficult it is to fit. the mechanic i saw today said he was going to pull the glovebox out and check the wiring to the front passenger airbag would this have anything to do with it or not?
Offline Rhyso
« Reply #14 on: 14 July 2010, 12:21 »
Sorry ignore me.  I thought it was the side airbag you were on about  :embarassed:
Yeah the glovebox would have to be dropped out although if you pull the side panel from the dashboard you can see the wiring in there.  Maybe a wiggle of that might help  :undecided:
Offline topher
  • Administrator
  • fully functioning
« Reply #15 on: 14 July 2010, 14:24 »
yeah that was my fault :grin: N131 is glovebox bag, N199 and N200 are side impact bags that are effected by the under-seat plugs
Offline mattGTI20
  • mattGTI20
« Reply #16 on: 14 July 2010, 23:11 »
cheers for the help i will just have to wait and see what happens when it goes in to him im just dreading having to pay out for a whole new airbag :sad:
Offline verrmaja
« Reply #17 on: 28 February 2017, 17:44 »
I have the same code coming up:
00589 - Airbag Igniter - Passenger Side - [N131]
Short to Ground - Active/Static
I changed the airbag and hte module, code comes up.  Could it be the wire or the plug?
Offline bgbazz
  • If it aint broke...I can fix it!
« Reply #18 on: 28 February 2017, 17:57 »
Just a thought...you changed the airbag and the module and the code still comes up? Did you actually clear the code after the changeover was done? I've made that mistake and it looked like the problem was still there...cleared all the codes and everything returned to normal.
As I said...just a thought.
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline verrmaja
« Reply #19 on: 28 February 2017, 18:15 »
Yes, i have the Autel MD802 tool, I tried clearing it and it comes up after I do a ignition on test, then start the car test and turn off the car and turn to ignition on and it still comes up.
