Author Topic: Vr6 Head Gasket  (Read 8302 times)
golfvr6
Vr6 Head Gasket
« on: 12 August 2003, 10:15 »
I think i might have a head gasket leak on my VR6. Not the usual type of leak, the problem is the vent on my expansion cap keeps leaking. I've tried various caps and a new expansion tank but it still leaks. It leaks more when i boot it. Compression test comes out ok. The question is if the coolant system is being pressurised by a leak in the gasket, then how long can i carry on driving it without big problems? cheers all.
Offline richandhazel
Re:Vr6 Head Gasket
« Reply #1 on: 12 August 2003, 13:09 »
I believe you can have your coolant checked to see if there are traces of combustion deposits/gasses in the coolant.
Offline mk1
Re:Vr6 Head Gasket
« Reply #2 on: 12 August 2003, 22:54 »
Is there a lot of pressure in the cooling system? I have done lots of head gaskets on vr6 engines and half were for oil leaks and half for exactly your fault. Use only wv gaskets, I also replace the stem seals. Job is not as bad as it looks, unbolt the exhaust manifold from the head and push back, just "crack" the bolt on the rear cam sprocket, time the engine and remove the chain tensioner, then take out the slack bolt and remove the sprocket from the cam, this alows you to take the chain off. The rest is just nuts and bolts. Check the condition of the top chain guide, have had to change some due to plastic breaking off, now thats a bigger job ::). Hope it is something simple ;). Steve.
Offline mk1
Re:Vr6 Head Gasket
« Reply #3 on: 14 August 2003, 19:09 »
 So you reckon i gotta change the  head gasket then?
Looks like it, some had a small electric coolant pump in the small hoses above the g/box. This is to circulate the coolant around the engine when off to stop heat soak boiling the coolant in the engine. Worth a look?. Steve.
golfvr6
Re:Vr6 Head Gasket
« Reply #4 on: 15 August 2003, 00:02 »
You reckon it might be the run on pump? I far as i can see it is working properly. The coolant only leaks out when driving, not if i just let the car run with the bonnet up.
Offline modulater
Re:Vr6 Head Gasket
« Reply #5 on: 15 August 2003, 02:38 »
GOLF VR6, have you thought about trying a product called water wetter in the coolant system?  It's supposed to raise the boiling point of the water so it might help.
golfvr6
Re:Vr6 Head Gasket
« Reply #6 on: 15 August 2003, 13:32 »
Yep i have thought of it, but i probably want to sort it once and for all really.
Offline mk1
Re:Vr6 Head Gasket
« Reply #7 on: 15 August 2003, 21:55 »
Raising the boiling point of the coolant wont change the pressure in the cooling system. Water wetter says it will help transfer the heat from the coolant to the atmosphere better. Driving, higher cylinder pressures, cap venting, I would do the HG before you have a bigger problem. Steve.
golfvr6
Re:Vr6 Head Gasket
« Reply #8 on: 23 August 2003, 17:27 »
Cheers for everyones responses. I've put radweld in and everything seems ok for now. Water wetter would probably help but not for long. Probably end up doing the gasket sooner or later....
golfvr6
Re:Vr6 Head Gasket
« Reply #9 on: 24 August 2003, 16:52 »
Another question..... i've been told that when there is a head gasket leak that pressurises the coolant system, all the coolant hoses go hard, is this true in all cases?
