Author Topic: Air con compressor  (Read 2221 times)
Offline Rhyso
Re: Air con compressor
« Reply #10 on: 07 July 2010, 14:44 »
Here's a thread with some pics and info
http://uk-mkivs.net/forums/t/354145.aspx
 :smiley:
Offline djshort_stuff
« Reply #11 on: 07 July 2010, 16:35 »
thanks alot Rhyso i found the sensor im now trying to bridge the sensor can you talk me through it please, never done it before. I have unplugged the clip do i bridge that part, theres 3 bits inside do i make sure i have all three bridged?
sorry your prolly getting fed up with my silly questions lol
Offline Rhyso
« Reply #12 on: 07 July 2010, 16:37 »
I can't as I've never replaced it so can't help any further I'm afraid  :sad:  Not an electrician either so I can't advise on how to bridge the switch.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 07 July 2010, 17:50 »
you don't need to re pressurise the system to change the switch, there's a valve under it that stops fluid escaping when you remove it. Mine was knackered due to it actually leaking fluid through the body of the thing
The switch shows up on VAG COM if its faulty too
« Reply #14 on: 07 July 2010, 20:24 »
And if the valve sticks you get a face full of gas, not a good idea before doing anywork the system should be drained of gas.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 07 July 2010, 20:28 »
not unless you've got your face next to it you plum :grin:
It's not any worse than doing an oil change, old oil is carcinogenic...
« Reply #16 on: 07 July 2010, 20:32 »
If you think it is safe thats fine, I work with air con everyday so tend to be very carefull.
« Reply #17 on: 14 July 2010, 11:30 »
Hello gents my a/c problem has now been resolved  :smiley: took it back to a/c specialist they said there are two faults one compressor is faulty also it wasnt getting an electrical feed, so they have fitted a new compressor, after fitting it the electrical problem sorted itself out fingers crossed it doesnt come back, but typical weather is rubbish now! Also had a cambelt change and water pump so just got a few other common faults to sort and car will be sweet, thanks for all your info.  :grin:
