Author Topic: Help Broke Down :(  (Read 3832 times)
Offline IBD4vid
Help Broke Down :(
« on: 05 July 2010, 22:09 »
Hey all was driving home when under 1 mile the car started slowing down and battery light came on :( so i pulled over and poped the bonnet but nothing , no leaks . tryed to turn it over ticks but doesnt start :( unplugged the battery and after a while plugged it in turned it and it started reved to 1000 then turned off.
Ive also noticed that there is ticking noise coming from relay 458
One guy pulled over and said its looks like its the starter motor could he be right?
Cheers :cry:
visit my car site www.mycarsevolution.co.uk
The GTI Rep Coming Soon
Offline IBD4vid
Re: Help Broke Down :(
« Reply #1 on: 05 July 2010, 22:22 »
sorry realy A4 is making a ticking sound when i turn the car over
Offline AlanD
  • MK5 2.0T 16v
« Reply #2 on: 05 July 2010, 23:44 »
When my battery died it would make a ticking noise when trying to start it. Dont suppose you have a battery charger do you?
Odd that it died whilst driving though, alternator? Im just thinking out loud here :undecided:
Offline IBD4vid
« Reply #3 on: 05 July 2010, 23:46 »
now thats the thing the battery is not dead. ticking coming from fuse box realy a4
Offline AlanD
  • MK5 2.0T 16v
« Reply #4 on: 05 July 2010, 23:49 »
Just because it unlocks and the mid / highline comes on etc doesn't mean its not dead. When mine started dieing all these things would work but it wouldn't start then a day later the midline and everything else died.
It doesnt sound like the battery though, might be worth trying to jump start it with leads? Would rule it out at least.
Offline IBD4vid
« Reply #5 on: 05 July 2010, 23:54 »
checked the battery and its got the green light on :( the engine turns over but doesnt start while the engine is turning there is ticking noise from the fuse box when i take relay a4 out it stops. like i said engine turns but doesnt start :( could it be a loose wire on starter motor?
Offline Gene Hunt.
« Reply #6 on: 06 July 2010, 01:05 »
Faulty coil ?.
Candy White ED35.
Offline BuckieGTI
« Reply #7 on: 06 July 2010, 07:43 »
Green light doesnt always mean that the battery is in good condition just the one cell that its connected too is good. Take it down to a garage and get them to load test it. This will eliminate it as a fault.
Offline IBD4vid
« Reply #8 on: 06 July 2010, 08:26 »
so it can't be because the relay fuse is fooked? the noise is coming from relay a4 (engine compoment  power supply relay)
Offline IBD4vid
« Reply #9 on: 06 July 2010, 09:43 »
battery was disconnected all night started it and car started fine i even reved to 4000 revs the whole time i had my foot reving it was working as soon as i stopped it stalled.
got the vag out to find out what it could be and it has 14 faults.
from what i could make out its a short somewhere.
if anyone can help it would be really appreciated
* Code Error* *
16575 - Fuel Pressure Sensor Short To Ground
17806 - Rpm signal short to ground
17833 - evap purge valve short to ground
17935 - intake camshaft control short to ground
17446 - (Unknown)
18011 - Internal Control Moduel
17435 - (unknown)
18727 - ( Unknown)
18582 - (Unknown)
The unknown ones only displayed code on vag :(
