Author Topic: R-Tech Customers cars and power graph gallery  (Read 218919 times)
Offline golf-sib
  • Турботазик
Re: R-Tech Customers cars and power graph gallery
« Reply #270 on: 21 October 2011, 21:08 »
Ignore, I scaled the diameter only, so you can tell me to take my GCSE's
Just used: πr²
2.5 (63.5mm)" = 4.90
2.75 (69.85mm) = 5.94
A scale off 1.21 or *121% try that  :wink:
« Last Edit: 21 October 2011, 21:10 by golf-sib »
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #271 on: 21 October 2011, 21:11 »
N75 in that log Nick.  MBC was jerking all the time!
Need to run it Parallel with the N75, its boosting too hard just with the N75, you need to clip it where I left it as its setup for that amount of load, not the load the N75 was giving due to your boost gauge. :wink:
 01455 617233
Offline Chris.
« Reply #272 on: 21 October 2011, 21:12 »
Will get it plumbed in like that tomorrow and do some more logging! :)
Click For Build Thread
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #273 on: 21 October 2011, 21:14 »
I know I shouldn't go by what my gauge says but it's only saying 16psi spike, still pulls like a train though. Can't see that stressing it too much lol
Offline Chris.
« Reply #274 on: 21 October 2011, 21:14 »
Just used: πr²
Think we need area.  It would be ok if the lengths were the same, but VR6 is longer.
I have:
Stock maf:
62mm width (ID)
96mm length
VR6 MAF:
76mm width (ID)
130mm length
That any help?
« Last Edit: 21 October 2011, 21:19 by Chris. »
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #275 on: 21 October 2011, 21:16 »
also I might plumb in my proper calibrated vac/pressure gauge I have at work and see what the proper boost figures are, just hope it has the range I need as I only really use it for vacuum, never tried it with pressure :undecided:
Offline blade4real2004
  • golf gti with a touch of .:R
« Reply #276 on: 21 October 2011, 21:20 »
hay nick desprately been trying to get hold of you all week can you give me a ring mate i emailed you to my numbers in the email cheers mate
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
Offline golf-sib
  • Турботазик
« Reply #277 on: 21 October 2011, 21:21 »
Just used: πr²
I have:
Stock maf:
62mm width (ID)
96mm length
VR6 MAF:
76mm width (ID)
103mm length
That any help?
In that case:
Just used: πr²
62mm = 3019
70mm = 3848
76mm = 4536 (you sure, this seems to huge as ID)
A scale of around 1.28 or *128% using 62mm and 70mm which is what nick was saying :afro:
1.8T AGU..
R135
  24
Offline Chris.
« Reply #278 on: 21 October 2011, 21:23 »
its actually 70mm,  I was measuring the square filter end which goes into airbox.  (that side is slightly bigger.
so the VR6 MAF is 28% larger. :)
Offline RTechUK
« Reply #279 on: 21 October 2011, 21:24 »
This is from a page I was reading when looking in to maf v injector flow rate.
"Stock 2.5" MAF = about 2.4" at the sensor, radius = 1.2"
New 3" MAF = about 2.8" at the sensor, radius = 1.4"
So, the area increase is:
[1.4*1.4] / [1.2*1.2]
1.96 / 1.44 = 1.36
 01455 617233
