Author Topic: Air Con Pressure sensor Easy to change?  (Read 19360 times)
Re: Air Con Pressure sensor Easy to change?
« Reply #10 on: 29 June 2010, 22:13 »
Not sure about your particular pressure switch, but the ones I've seen contain two switches, therefore four wires.
One switch cuts out the compressor when the pressure is too low, and the other pair cuts out the compressor when the pressure is too high.
If you can check with a circuit diagram what the normal operating condition is, then unplug the switch, and as Colinv says, use paper clip or bit of wire to let the system think the pressure is correct and check if it works correctly.
All you are doing is bypassing the pressure sensor to see if things work properly without it, and thereby seeing if it is what's causing the problem.
But at least we all think you don't need to de-gas the system.
I work with aircon on a day to day basis, to replace pressure switches does normally mean de gassing the system, to be honest any work on the air con system should not be tackled on a diy basis.
Offline h8v
« Reply #11 on: 30 June 2010, 08:23 »
I bow to your superior knowledge, Wayne.
All the pressure switches I've dealt with have had a valve behind them, so they could be changed without degassing the system.
Maybe things are different now!
Offline Len
« Reply #12 on: 07 April 2015, 16:45 »
So can it be done without degassing?????
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #13 on: 07 April 2015, 17:08 »
Been reading up and from what I have seen can be done without degassing!
From the amount of views this thread has had it must be a common problem!
www.sas.org.uk
www.the-ace.org.uk
