Quote from: Diamond Hell on 27 June 2010, 19:25Quote from: jezza16v on 26 June 2010, 22:45Wouldn't welding up the sunroof be more effective at stiffening the body than bonding the windscreen........?No, because of the amount of reinforcement put in by VW to compensate.Sunroof shells are supposed to be stiffer.I would say it would, Can you remove most the sunroof and just keep it to fill hole to get rid of some weight?, as i dont have a clue what its purpose is, when I had no windows for a month it done nothing to get colder air in, probably let it out but it didn't cool me down in the slightest !Does that mean heavier too then?
Quote from: Neo Badness on 28 June 2010, 00:15Quote from: Diamond Hell on 27 June 2010, 19:25Quote from: jezza16v on 26 June 2010, 22:45Wouldn't welding up the sunroof be more effective at stiffening the body than bonding the windscreen........?No, because of the amount of reinforcement put in by VW to compensate.Sunroof shells are supposed to be stiffer.I would say it would, Can you remove most the sunroof and just keep it to fill hole to get rid of some weight?, as i dont have a clue what its purpose is, when I had no windows for a month it done nothing to get colder air in, probably let it out but it didn't cool me down in the slightest !Does that mean heavier too then?
