Author Topic: cleanning headlining  (Read 3857 times)
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
Re: cleanning headlining
« Reply #10 on: 29 June 2010, 00:32 »
can you get hold of a vax hoover or a wet extraction machine? this will give you more uniform results
I can  :smiley: my mates garage has one, was going to use it next week on my seats, boot and carpets as there in desperate need of a good clean ill give it a blast on the headlener, didn't think about it till you said it.
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline Dan J
« Reply #11 on: 29 June 2010, 01:50 »
cool!! get some APC or your chosen product and put it in a spray bottle with a fine mister head on it and dampen the headlining, if you over soak it it will sag, also split your cleaning areas into 4 sections as this will minimise the risk of over soaking it.
keep an eye out for snags on the end of the hoover nozzle as this can catch the lining and rip it.
Offline godsANGER
« Reply #12 on: 29 June 2010, 12:37 »
Got my APC back from work so when i get back from my weekend wet vac time lol. is it easy with the wet vac to do the headlining ?
Thanks
Offline Dan J
« Reply #13 on: 29 June 2010, 13:25 »
yep just go at it gently ie no hard scrubbing and move the nozzle across your working area slowly, id also dilute the apc a little bit,
prepare to get water running down your arms lol and occasionally on your face.
