Golf mk4
Wazzzer
R32 334mm Brakes
Topic: R32 334mm Brakes (Read 1710 times)
Hulmie
White MK4 1.8T AGU K03s
R32 334mm Brakes
18 June 2010, 23:29 »
What is needed apart from disc's to fit the R32 big brakes on a 1.8T
Steve_PD
Serious forum addict
Cruising around in a Land Cruiser
Re: R32 334mm Brakes
18 June 2010, 23:42 »
Calipers, carriers, discs and pads. think the brake hoses are the same
Hulmie
19 June 2010, 09:00 »
anyone know if this is a cheap conversion and how well they work.
I know i could go with the 312mm setup for around £150, but fancied something bigger
Steve_PD
19 June 2010, 10:48 »
replacement discs are very expensive
Hulmie
19 June 2010, 10:50 »
yeh thought that would be a major factor, should say calipers aint cheap either?
Steve_PD
19 June 2010, 11:20 »
you can get a second hand setup for around £250-300
Purely VAG
Reply #6 on:
19 June 2010, 14:20 »
Disc prices have come down actually, it used to be impossible to get a set below £190 now you can get a set for £110. Clearly the cheaper manufacturers are in on them now.
You just need calipers, carriers, discs, pads.
✉ Jrd@PurelyVAG.co.uk //
www.PurelyVAG.co.uk
Golf mk4
Wazzzer
R32 334mm Brakes
