Author Topic: Misfire...(AGU owners help needed)  (Read 5990 times)
Offline topher
  • Administrator
  • fully functioning
Re: Misfire...(AGU owners help needed)
« Reply #10 on: 19 June 2010, 19:59 »
no fault codes doesn't necessarily rule out the coil packs
does it do it at idle?
was your mate not brave enough to swap ignition amps with you in the cause of diagnostics? :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 20 June 2010, 09:04 »
thing is it only does it now and then, it was at idle too...
