Author Topic: Electronic Throttle Response?????  (Read 1510 times)
Offline dubsport
  • TDI POWAR!
« on: 13 June 2010, 20:42 »
Looking to replace the pipercross panel filter with an induction kit. looking at a Pipercross 'Velocity Intake System' in the link below, but what the hell is electronic trottle response?
http://www.venommotorsport.com/product_details.php?id=15369&manufacturer=Pipercross&category=Filter
also looking at the Carbonio Intake below, which would you guys recommend?
http://www.awesome-gti.co.uk/product.php?xProd=3682&xSec=75
Thanks ALOT!!!   :smiley:
Offline Jimp
Re: Electronic Throttle Response?????
« Reply #1 on: 13 June 2010, 20:56 »
I think it's to do with the throttle body as early 1.8T's had a cable throttle instead of fly-by-wire throttle.
Not low enough mk5
Not on the road enough mk3
Offline dubsport
  • TDI POWAR!
« Reply #2 on: 13 June 2010, 21:01 »
mines a 2001 so im guessing the pipercross induction kit wont be compatible?  :undecided:
Offline dubsport
  • TDI POWAR!
« Reply #3 on: 14 June 2010, 17:23 »
anyone?  :smiley:
Offline T_J_G
« Reply #4 on: 14 June 2010, 17:42 »
I don't see what difference it makes. Assuming yours is an aum you'll need a seperately 19mm breather filter for the secondary air
pump.
Offline AudiA8Quattro
« Reply #5 on: 14 June 2010, 21:58 »
Electronic throttle has no throttle cable, or known as fly by wire.
Offline Jimp
« Reply #6 on: 15 June 2010, 11:59 »
I don't know if the kit would fit or not tbh. There might be different fittings on the fly-by-wire throttle? Someone from the mk4 section would know.
Not low enough mk5
Offline T_J_G
« Reply #7 on: 15 June 2010, 15:24 »
I really don't think they are.
