Author Topic: My New wheels rub sometimes? 18x8J ET 42?  (Read 11325 times)
Offline johnford60
  • MK7 GTD 3 Door
« on: 08 June 2010, 13:24 »
Hi,
Got some new wheels on my MK5 GTI, and they rub the splash guard when corning hard etc, they have supplied me 18x8J with a ET42 offset, is this wrong or wright?
My old Monza 2 where 18 x 7.5J by Et51 offset I believe.
John
John
Offline GtiJames
Re: My New wheels rub sometimes? 18x8J ET 42?
« Reply #1 on: 08 June 2010, 13:54 »
what wheels you got? and are you lowered?
as mine are the same offset as yours 18x8 et42 speedline turini's and as you can see from the pic I have got it lowered too and they don't rub
Offline johnford60
  • MK7 GTD 3 Door
« Reply #2 on: 08 June 2010, 14:52 »
I got BBS CH ( Reps ).... and every wheel will rub if you push the car through corners ?... Wel thats the size it says on the box :rolleyes:
oh and not lowered!
« Last Edit: 08 June 2010, 15:02 by johnford60 »
John
Offline johnford60
  • MK7 GTD 3 Door
« Reply #3 on: 08 June 2010, 15:05 »
From the look of your car, the wheels look like the sit in quite a bit still, mine look like they are setting further out?
John
Offline GtiJames
« Reply #4 on: 08 June 2010, 15:33 »
i aint no expert but your offset maybe wrong, it is sometimes a risk when buying reps as they are not made to the same high specification as genuine wheels, hence the price difference.
before i got my turini alloys I had to fit 10mm spacers to clear my brake calipers when using the oem pescara alloy which was et51, so that gave me a total offset of et41 - with this I got rubbing on the front arches but never the rear
there is solutions such as adding negative camber but this can ruin the handling, or arch rolling..
where did you buy them from and can you return them?
Offline johnford60
  • MK7 GTD 3 Door
« Reply #5 on: 08 June 2010, 15:43 »
« Last Edit: 08 June 2010, 16:27 by johnford60 »
John
Offline johnford60
  • MK7 GTD 3 Door
« Reply #6 on: 08 June 2010, 15:45 »
« Last Edit: 08 June 2010, 16:29 by johnford60 »
John
Offline GtiJames
« Reply #7 on: 08 June 2010, 15:53 »
i see your on standard suspension and they do stick out quite a bit
what tyres did you get put on, 225 or 235, if the latter then that might be causing the rubbing
Offline johnford60
  • MK7 GTD 3 Door
« Reply #8 on: 08 June 2010, 16:05 »
225 on mine?... Unless the wheels in the box where wrong
John
Offline johnford60
  • MK7 GTD 3 Door
« Reply #9 on: 08 June 2010, 22:55 »
Any one got any other idea's? :embarassed:
John
