Author Topic: STARTING PROBS STILL  (Read 4771 times)
Offline danmusic24
Re: STARTING PROBS STILL
« Reply #10 on: 14 June 2010, 08:14 »
still wont start, but found out the fuel pump is priming when trying to start so thought maybe dizzy! so replaced and still nothing just spinning over no spark..time for a auto electrician i think,spent so much money..but any other thoughts would be nice :undecided:
Offline indich
« Reply #11 on: 06 December 2014, 20:55 »
Did you ever sort this problem out.. coz im getting the exact same problems. .. any advice will do...
Offline Foreveryoungaus16v
« Reply #12 on: 06 December 2014, 21:55 »
Just take it to a Vw specialist or equivalent.  No point spending out on money unless you know what the exact problem is.
163 BHP (TSR POWER RUN)
Offline chris_d66
  • Golf GTI 16v,A3 1.8t,Rocco, Range rover V8
« Reply #13 on: 07 December 2014, 11:07 »
Have you checked the water coolant temp sensors if it is reading the engine is hot then you will get a lean mixture instead of a rich mixture needed to start the engine.
If the sensor is within tolerances between hot and cold then you probably wont get a error code.
New toy1990 Scirocco I feel a 16v conversion coming on.
« Reply #14 on: 07 December 2014, 12:02 »
Have you done this have you checked that...just take it to a garage.
Offline GOLF-MK3-GTI
« Reply #15 on: 07 December 2014, 20:39 »
Sounds like a fault I had on mine.
have a read here.
http://www.edition38.com/forums/index.php?showtopic=505337
