Author Topic: New Door Speakers  (Read 2146 times)
Offline Charge
  • Into Notion, Out of Motion
New Door Speakers
« on: 03 June 2010, 19:06 »
I have a '90 mk2 (before door speakers were fitted (dash mounted)) and want to fit some Door Speakers.
I have already run the wiring through, and bought the correct speakers, but this means I am running 6 speakers off a connector that can only cover 4 (8 connections). Can I just buy another connector? Or what? The radio I have just bought only has 6 wire slots also. Do i just combine some connections?
Also, the connectors have the clips built in, any way of removing these to connect the wire up properly?
Any help would be great.
Offline Charge
Re: New Door Speakers
« Reply #1 on: 13 June 2010, 01:49 »
Anything? If you dont understand I can try and take some pics tomorrow.
Offline jmsheahan
« Reply #2 on: 13 June 2010, 12:52 »
I can't help with the wiring queries but regarding the connectors with clips built in, is this what you are after?
http://www.golfgtiforum.co.uk/index.php?topic=157724.0
Offline Charge
« Reply #3 on: 13 June 2010, 13:01 »
Cheers for the reply.
But where would they connect to the original looms?
