Author Topic: best cheap coilovers  (Read 3753 times)
Offline will gti
  • ARZ 1.8T
Re: best cheap coilovers
« Reply #10 on: 02 June 2010, 23:10 »
GUNNA GO FK I THINK AS JAM DONT GO LOW ENUFF AND TOOO MUCH BAD SHIZZ BOUT HOT T
WHEELS IN SIG FOR SALE FERB'D WITH NO CURBING, ALL WITH GOOD TYRES GOODYEAR NCT 5
Offline DarkGti
« Reply #11 on: 02 June 2010, 23:10 »
the ride on the hottuning collies aint that bad ive had them for over a year with no problems untill i noticed the other day both fronts were leaking, i had weitecs on before these and they were rubbish
Offline vwfiend
« Reply #12 on: 02 June 2010, 23:33 »
I think all coilies go down to 100mm lower (ARB pending) but they advertise as less for TUV approval or something. How come your Weitecs were gash? I nearly bought some but Im too tight!
Offline DarkGti
« Reply #13 on: 03 June 2010, 00:07 »
they were very crashy and sqeeked alot, only had them on for 6 weeks and sold them for £225
Offline Purely VAG
« Reply #14 on: 03 June 2010, 00:10 »
Had my JOM/Hot tuning ones on for 2 years, Not 1 problem.
The people that complain is the people that treat coilovers as standard struts and go over speed humps at 90mph.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline vwfiend
« Reply #15 on: 03 June 2010, 00:27 »
Or people who live in the Norfolk countryside where roads are levelled by the blind
Offline Purely VAG
« Reply #16 on: 03 June 2010, 00:35 »
lol ^
Well thats another thing, im careful and roads are Ok round here.
Offline Dan34
  • VTEC Powerzzzz
« Reply #17 on: 03 June 2010, 00:37 »
+1  :grin:
« Reply #18 on: 03 June 2010, 09:04 »
I would avoid the hottuning ones.
Offline rakesh27
« Reply #19 on: 03 June 2010, 20:27 »
Ive brought JOM from ebay £180 free P+P, had them for over a year now, not one problem.
Remember once fitted you have to give it time to settle in, you cant drive over speed bumps like before, you have to go much slower and depending on how low your car is you may have to go over speed bumps on one side of your car not through the middle as youll probably hit something underneath.
Some companies also provide 1yr warrenty, coilovers feel alot harder then springs but once settled in the ride wont feel as harsh.
Some people go for out and out low, bad thing about doing that is you have to be careful of every bump in the road and weight eg more passengers most likely your wheels will be rubbing against the arch, other people just make sure theres a tiny gap between arch and tyre not noticeable, with this you dont need to worry about weight and you can drive fast knowing that nothing will brake, stiil have to be careful of the bumps.
More often its just luck when purchasing suspension parts, so long as its fitted correctly and you drive sensibly they should last a while, also after fitting its best to get tracking done a little while after.
Good luck
