Author Topic: car wont start (1.8t)  (Read 1210 times)
Offline jimmy1888
« on: 02 June 2010, 17:18 »
Hi all,
As heading states my car wont start! it started about 4 oclock this afternoon, went in to petrol station to fill up and when i came back out and tried to start the car i got nothing! the dash board lights come on and im sure i can hear the fuel pump prime but the car doesnt even attempt to turn over. the car pump starts and runs fine when going if that helps!
Any ideas
cheers
jim  :smiley:
Offline golfgtidan
Re: car wont start (1.8t)
« Reply #1 on: 02 June 2010, 18:09 »
starter motor sounds a possible cause, check the earth on the back to make sure its not snapped off, could be the unit itself, give it a wack with a hammer and block of wood then try starting it...
1999 1.8t : Winter Pack : Kamei Mesh Grille : Forge 007p D/V : Carbonio Cold Air Intake : R-tech remap : 18" Toora Alloys : -30mm Eibach Springs : Smoked Side Repeaters : Hella Magic Colours Rear Lights : Hella Black Headlights : "hid" Headlight Conversion : Aero Blades Front & Rear: ECS KVW100 Window Control Module : Milltek resonated cat back
Offline linz
  • vee-dub
« Reply #2 on: 02 June 2010, 19:51 »
yep could be the starter motor
unless u put in the wrong fuel ;)
Offline richw911
« Reply #3 on: 02 June 2010, 19:53 »
99% starter motor  :smiley:
