Author Topic: Look what some tw@ has done!!!!  (Read 6281 times)
Offline spenny_b
Re: Look what some tw@ has done!!!!
« Reply #10 on: 28 May 2010, 18:08 »
I know, cr4p eh?...IIRC from the good old paper catalogue I used to receive, it was basically a bar of the same plastic that is melted using a special soldering iron...pretty much soldering with plastic.
Mk 6 Golf GTD - Reflex Silver
Porsche 911 GT3 Mk2 (996)
Westfield - Trackday toy
Offline Saint Steve
« Reply #11 on: 29 May 2010, 18:37 »
Found it http://www.youtube.com/watch?v=cpdnnNw4wlc
:shocked: :shocked:God , how easy is it now to steal an Rns510!!!!!. At least with the mk5 you had to take the top of the dash board out.
Offline am1w
« Reply #12 on: 29 May 2010, 18:44 »
A very good point.
It seems they are being separated from the cars in large numbers on the continent.
Not forgetting the broken glass etc they will leave behind.
 :shocked:
« Last Edit: 29 May 2010, 20:17 by am1w »
Offline AlanD
  • MK5 2.0T 16v
« Reply #13 on: 29 May 2010, 19:10 »
You mentioned it had snapped a clip. I also snapped a few clips when I had a small coming together. They just plastic welded it, worked a treat.
Actually, thinking about it that might not be the best idea. Mine was on the front light cluster to hold it in, its not often if ever Ill need to take them out, front bumper on the other hand you might well at some point need to take off for whatever reason.
