Author Topic: Sprintbooster solves a problem  (Read 12687 times)
Re: Sprintbooster solves a problem
« Reply #10 on: 24 May 2010, 16:13 »
You obviously didn't read my first post through or I made a mess of it.
Yes it does work.
The reason I didn't post up about it before was because I knew the thread would end up full of crap because people don't read things properly. I said quite clearly in the first post that if you question why you need one you don't. Simple as.
This thread is in reply to peoples queries from another thread that went a bit off topic.
So for one last time IT WORKS!   :grin:
I drive a normally aspirated old skool GTI as a daily driver. When I get into the mk6 you can really notice the difference in throttle response. I stall it sometimes when I've not driven it for a while until a re-adjust. With the Sprintbooster attached this doesn't happen. The turbo lag has gone into negative lag it you like almost like the turbo has become psychic!  :smiley:
« Last Edit: 24 May 2010, 16:17 by Exonian »
Offline Horney
« Reply #11 on: 24 May 2010, 16:27 »
It won't cure Turbo lag.
nick
« Reply #12 on: 24 May 2010, 16:30 »
I give up.  :rolleyes:
The throttle lag feels like the turbo is laggy. The sprintbooster allows the ickle wee K03 spool up properly making it feel like there is no lag.
thread subscription de-activated. Ta ra.
« Last Edit: 24 May 2010, 16:32 by Exonian »
Offline Horney
« Reply #13 on: 24 May 2010, 16:33 »
Steady on!
I was just saying that a resistor cannot cure Turbo lag which is what your last post suggested.
I think what you mean is it takes out the slck the drive by wire system seems to have over a proper cable throttle. My Polo TDI has a drive by wire throttle and it is a bit rubbish.
Nick
Offline am1w
« Reply #14 on: 24 May 2010, 16:37 »
I thought it was to speed up throttle response. I don't suffer from any turbo lag. I just want the car to be a bit more reactive. I suppose this means a re-map. Will happen soon.
Offline ajmoir36
« Reply #15 on: 24 May 2010, 19:51 »
What about fuel economy is there any effect on that?  If it sort of does turn up throttle position of the pedal so does it make it like 10% throttle like 15% and so on what happens at 100% does it make it 150% throttle? I wonder what the ECU makes of that.  I suppose pedal off is still pedal off mind.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
« Reply #16 on: 24 May 2010, 20:25 »
Steady on!
Nick
Thank you someone with sense, I still think you could end up with issue in the future, they must build a small amount of slack in for a reason.
« Reply #17 on: 25 May 2010, 05:32 »
Right, apologies, I was very busy yesterday so had to type in a rush and obviously was confusing everybody hence had to abandon the thread for a bit before things got even more muddled. And it's not as if there isn't a certain amount of Wumming goes on in the mk6 section from time to time which I was trying to be wary of. I thought I'd covered most things in the first post which genuine mk6 owners would either be familiar with or not be bothered about. It's more bothersome for those of us who own another vehicle that dosen't suffer the long pedal travel and slow responses. This is a very mk6 GTI specific problem that I also noticed to a slightly lesser extent with my mk5 GTI previously. Maybe I didn't go into enough detail in the first post but I didn't want to write a bloody book on the subject.
So:
Steady on!
Nick
Yep, my bad as the Yanks would say. What I meant was the throttle lag had disappeared and I was trying to liken it to a reversed version of turbo lag, seemingly like a psychic turbo.
Trying to explain things when you're in a rush ain't good. Lesson learned, apologies for misunderstanding.
I've owned all manner of VW TDIs and DBW 1.8Ts and none have had this issue bad enough to bother me once re-mapped. It just seems more inherrant with the floor hinged pedal on the mk5 petrol models. I had a mk5 2.0 TDI some years ago and that didn't seem so bad but it never seemed as lively to me as my previous 1.9 TDIs.
See above. Re-mapping alone may be the answer for you, but I needed a re-map of the engine and throttle pedal to satisfy me!
Basically it amplifies any throttle input and means you get 100% throttle at about three quarters of pedal depression. I've not tried it but an educated guess would say the final quarter of pedal travel would now be redundant. Which if you read post #1 is what I want. The pedal travel is too long for me.
So yes, fuel economy will be affected if you make use of the vastly improved throttle response too often. But just like when you re-map, you soon ease off and adjust your driving style once the novelty wears off to take advantage of the improved dynamics without hooning around.
And finally to Wayne, yep, maybe I don't have any sense but hey ho. Someone's got to experiment a little. I did research this for quite some time (see post #1) before coughing up my hard earned and the company have been round a few years now. I've not read any horror stories. If I'm unlucky I may get to write my own though  :lipsrsealed: Time'll tell.
You don't live too far away from me by the looks of things (Im in Devon) so if you want a demonstration of the issue that some of us believe mk6s have I'd be happy to let you see for yourself. The small amount of slack is very definately there for a reason, and that reson is likely to be some beaurocrat somewhere who's probably in the same department that insists the door mirrors are a funny shape that gives you blind spots. Insert your own anti EU Clarkson quote here to suit.
I had a Polo GTI 1.8t a few years ago. That had the complete opposite throttle response to the mk5 and more so the mk6 Golf. VW even made light of the fact in some witty adverts showing some bloke keep overshooting his parking space in his Polo GTI (there's a few more similar vein ones on youtube), so we know it's something engineered in to these latest generation cars.
For me, I'm no boy racer, I rarely use high revs but I do like a snappy throttle response and good mid range punch. If I end up with an issue in the future I'll be sure to come back and warn everyone.
Offline FroGTI
  • Wheel nut
« Reply #18 on: 25 May 2010, 07:20 »
Sounds like a good mod to me, Exonian. Certainly a lot cheaper than a remap (mine cost me £550 :sad:). Thanks for the very detailed write-up.
Offline Ess_Three
« Reply #19 on: 25 May 2010, 07:46 »
It basically makes the range of 0% to 100% throttle happen over a smaller range of throttle pedal movement.
I've never felt the need before on other VAG cars...but the Mk6 GTI has tragic throttle response.
The sprint booster makes it possible to blip the throttle without feeling like you are going up stairs...and makes the car far motre lively.
sure, you can get the same affect by pressing the pedal further...but try doing that whilst heel-toeing.
It can't open the throttle any further than the TB allows...so no damage can occur. It doesn't affect enough for that to happen.
..but gaining motorcycles.
