Author Topic: N75 backing off the boost  (Read 11945 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: N75 backing off the boost
« Reply #50 on: 06 June 2010, 22:27 »
At last you have some :afro: i forgot to pm you Wes about aero's still couldn't get any  :rolleyes: and with the issues this week it went over my head  :lipsrsealed: :embarassed:
2000 Mkiv GTi 1.8T AGU
Offline gti_shaun
« Reply #51 on: 08 June 2010, 00:11 »
can you see what throttle valve opening you are getting
 :laugh:
ive got a new gasket for between manifold and turbo just have to find time to fit it
good luck with that  :undecided:
That bad to fit in situ then?  i was hoping downpipe off to check for cracks on turbo, then three turbo bolts out, loosten turbo off with water and oil pipes on and then try and clean mani and turbo mating surfaced by sliding sand paper inbetween, slide new gasket inbetween, tighted up ans bobs ur uncle fannys your aunt, not the case then?
