Author Topic: idling! any ideas?  (Read 1616 times)
Veedubgt18v
idling! any ideas?
« on: 07 December 2004, 23:56 »
right
when i start my car it idles absolutely fine, when i have driven it a bit tho this changes. when i stop the revs sit at about 1250 sometimes they stay there and sometimes they drop again to 900 ish. i can 'force' it to drop the revs by reving it to over 3000 when the revs drop when i come off the gas they go to 900. if i dont do this they stay at 1250. has anyone got any ideas? i tried the clean isv trick and resetting my idle. i reckon its a vacuum fault but cant find anything! help!
ta ed
ps its a 1992 8v pb engine
Offline Overseer
Re: idling! any ideas?
« Reply #1 on: 07 December 2004, 23:57 »
check all vacuum hoses etc for leaks (or that they're on at all!) and make sure your air filter is clear.
Veedubgt18v
« Reply #2 on: 07 December 2004, 23:59 »
yeah i done that, my  filter is clean and the only vacuum pipe i can find disconnected is for the warm air flap in the aribox but this has been off about a year and has never caused bother, i blocked the engine end of it. cheers for the speedy reply!  :grin:  just gonna keep hunting i suppose! better check the o ring on the idle screw thinking about it
Offline Overseer
« Reply #3 on: 08 December 2004, 00:05 »
blocked engine end?
a similar thing on mine was keeping the idle high.. it was meant to be connected to something... along with the fact the brake servo hose on mine was dodgy :)
g'luck!
Veedubgt18v
« Reply #4 on: 08 December 2004, 00:19 »
yeah where the pipe goes into the vacuum circuit i blocked it. oh well i will have to keep looking!
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #5 on: 08 December 2004, 09:22 »
When was the last time u cleaned the throttlebody out??
With mine there's was so much sh!t is was stopping the butterfly closing properly and thus engaged the idle switch. Check the throttle cable tension too - could be too tight ... again not letting the throttle completely return to rest.
Lastely check the idle switch - make sure there's no borken or fractured wires.
Hope this helps  :wink:
« Last Edit: 08 December 2004, 09:32 by davidhawkins_78 »
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
