Author Topic: Mk2 16V Turbo - Original Stealth Racing car  (Read 138262 times)
Offline SoundillusioN
Well the obvious answer is somethings shorting it out..  :grin: not sure what, you may need to check it's not related to the starter and it's wiring maybe???
Offline Sam
  • Sam I am
Offline F17BAD
  • Golf MTM S3 GTI TURBO
keeping you busy is the old girl mate
all the best with it   :smiley:
Not no ordinary GTI....
www.mixcloud.com/kells/
Does it pop the fuse when the key is on position 2 before you go to start it?
Offline i_am_me
try unplugging the pump,then turn the ignition on.
if it still blows the fuse its the live shorting out.
if it doesn't pop then its most likely a faulty pump.
<br />
If at first you don't succeed skydiving is not for you
Offline Sam
  • Sam I am
Yes, it will pop a 15, 20 but not 30 but will not start on a 30. f**ked fuel pump as i_am_me said is the most likely problem.
Damn... seems like she's having a bit of a midlife crisis then!
Offline lewis1641
  • stuck in the 90's
i think it is time to scrap it sam. when do you want me to come and get it?
Offline Sam
  • Sam I am
Now, £50 your way  :lipsrsealed:
Offline lewis1641
  • stuck in the 90's
i will  have to charge you a little more for wheel and tyre disposal.
i am sure it will all be sweet in a few days
