Author Topic: Mk2 16V Turbo - Original Stealth Racing car  (Read 138212 times)
Offline lewis1641
  • stuck in the 90's
Re: Mk2 16V Turbo explosion prevention project- Operation boost
« Reply #200 on: 04 April 2011, 15:31 »
you know the problem sam, you've got too many valves.
i want that garage!
Offline lemski
  • 16v
« Reply #201 on: 04 April 2011, 16:35 »
i think the problem is u own a turbo'd mk2. but i also want that garage. i could have all my spaires in there pluss my car and still lots of room.
back to my serious thoughts sam. rings on 1 and 4 maybe if the oil n such is all on them 2 like u said at the meet. have you gauged the bores to see how worn they are
Offline Sam
  • Sam I am
« Reply #202 on: 11 April 2011, 17:46 »
Ok, got a scrap 8v block today and a medium grade honer to try on it this evening to get my skills before doing the real thing, will post up before and after shots to see what you think and weather im up to the job [:s]
Here is a lovely looking piston after taking off the rings
here is my practice block
and here is my first go!
So... any top tips?
Offline SoundillusioN
« Reply #203 on: 11 April 2011, 17:50 »
Awesome.. good thinking with the practice block. When I saw that piston I though it was yours for a sec!  :shocked:
Looks good but not sure how it's supposed to be as I've never done it but looks like other pics i've seen... How much was the honer and how long did it take you to do one bore?
Offline Sam
  • Sam I am
« Reply #204 on: 11 April 2011, 17:59 »
That piston is from my block  :laugh: number 4 is pretty much the same but has caused no damage.
The honing tool was £25 from machine mart which is fine for a few blocks, any more and you want snap-on or somthing of a similair quality (according to a mechanic I spoke to today). The quality of the stones varies too, the ones I am using are a medium grade and medium quality. As for time per bore it depends on how much of a tolerance you have, I was on this for perhaps a 1 min which has taken off the glaze but I have not managed to create the 45deg cross hatch, prehaps a little closer to 20deg. If you watch a video of them doing this on a Motocross engine it will be in and out for 20 seconds if that so not quite sure whats best?
« Reply #205 on: 11 April 2011, 18:21 »
fook me!... surprised if it wasn't smoking like biatch!
Forgot about the cross hatching requirement... love the fact that you're tackling all this though. big thumbs up. :afro:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #206 on: 11 April 2011, 18:25 »
Should have a 60/40 degree cross hatch your doing well mate  :wink:
Offline Sam
  • Sam I am
« Reply #207 on: 11 April 2011, 18:26 »
She was, that was the initial problem... where the f**k is all this smoke coming from? Then when she started rattling and stalling with smoke pouring out of the engine breather pipe I knew there was only one thing for it.. load her up with all my stuff from uni, put on a nappy and make the 80 mile trip from home. Needless to say cutting out on every major roundabout between Leicster and Grimsby left that nappy truely sodden. As for doing to work myself, live and learn (and I have no money to speak of)
Cheers, i thought it was 45/45 like a knurling. Will have another bash now using a little more pressure and a heaver oil, will post pics up asap
« Last Edit: 11 April 2011, 18:28 by caistor_bmx »
Offline emery1990
« Reply #208 on: 11 April 2011, 18:28 »
If I can do megasquirt anyone can  :laugh: Well, I'll back this up tomorrow when my battery is charged up and see if I have just fixed my issue!
And if I map it myself ( with a base map to start with ) then literally anyone can do it!
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #209 on: 11 April 2011, 18:39 »
Just use a bit of fresh engine oil mate  :smiley:
