Author Topic: poly carbonate or perspex???  (Read 8808 times)
Offline johnson6672
Re: poly carbonate or perspex???
« Reply #10 on: 17 May 2010, 19:33 »
i made my own,
hardest thing is fitting the rear window, if you cut it to the same size as the hole it's easy to fit but it may wobbel, so cut it to the same size as the glass out of the rear windown,  thins makes fitting it somewhat more intresting as you have to force the curve into it whiles fitting but once fitted it stays and won't wobbel
Cheers, plan is to use the origanal glass as templates, all depends if i can get the stuff from work.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline RyanMac
« Reply #11 on: 29 August 2010, 09:55 »
whereabouts did you get your polycarbonate from as I plan to replace my windows when the car is getting resprayed.......
What thickness do people use?
I am looking for a cheap place though as the missus is starting to ask questions as to how much this car is going to cost me.......
Offline Horney
« Reply #12 on: 29 August 2010, 10:00 »
I got mine form a chap on Club GTI.
http://www.clubgti.com/forum/showthread.php?t=209821
Nick
Offline mmaattyyg
  • i need anger management as i dont take advice well
« Reply #13 on: 01 January 2011, 23:41 »
 there normally 4 mil thick ! poly is better as it doesnt shatter and is stronget than perspex ! you can get a full set for most cars for about £200
check out this ebay link/item number 150455825609 guys name is tony and is very helpfull and knows his stuff ! good luck anyway
i need anger management as i dont take advise well ......
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #14 on: 03 January 2011, 19:25 »
Not this again.  :rolleyes:
