Author Topic: Khare's problem thread - Engine mount and screeching noise page 15. EUROPE TRIP!  (Read 25171 times)
which one o these is it you need, if unsure check old belt it should have the length printed on it somewhere:
2.0 16v 92-95 (-AirCon)         6PK0976
2.0 16v 96-97 (-AirCon)         6PK1038
Offline Khare
  • The bear that khares
Got it ordered from ECP RJ, hopefully the monkeys will get the right one  :smiley:
Offline Paul86S2
The vw belt is 1033mm long on the later engine without aircon and the GSF one is 1038mm long and fits fine.
You'll need to remove the power steering belt so you might as well replace that as well if you don't know how old it is. Only about £3 from GSF for the power steering belt.
Paul
Offline Khare
Paul
PAS belt I did a few months ago so I'll leave that one. I know how to replace the belts so I shouldn't be needing to bother the forum  :tongue:
Cheers Paul.
Offline Len
Famous last words there Khare Bear!  :wink: :laugh:
www.sas.org.uk
www.the-ace.org.uk
Offline JC
  • Back in the North.
and i thought this engine was getting stripped, worked, and all new gaskets / belts etc before fitting.
Oh how the plan changed and FAILED  :grin:
Offline Khare
The sump gasket was changed.....Danny did it....Obviously GSF quality shined through though.
Offline LazyLunatic
  • MK3 20VT Project
solid front mount ftw. i got mine through ebay but i think its the same guy off clubgti. make sure you use LOTS of threadlock or it will fall off! :lipsrsealed: :D :embarassed:
« Last Edit: 14 July 2010, 11:59 by LazyLunatic »
Offline Khare
Yeah same guy, I looked him up. I will use plenty of thread lock not to worry. Last thing I want is engine mount coming loose  :grin:
Offline VR6_Wherry
solid front mount ftw. i got mine through ebay but i think its the same guy off clubgti. make sure you use LOTS of threadlock or it will fall off! :lipsrsealed: :D :embarrassed:
That's a man talking from experience!  :grin:
