Author Topic: Where can one obtain a Golf Edition 30 Manual Shifter cheaply?  (Read 45886 times)
Offline am1w
With the 3000+ ED30's on the road... it wont be exclusive either :laugh:
It will on a Mk6! :tongue:
Spoilt sport! :wink:
Are you going to get one?
Manual or DSG?
tempted.. but i will wait to see how they look first. and how much? :wink:
Can I tempt you further? :wink:
Go on, you want one ... just playing hard to get arn't we! :laugh:
Manual or DSG?
Offline AlanH
I'd be interested in the Ed 30 Manual Shifter, having had an Edition 30 prior to the GTD. Assume it would fit the manual GTD? And talking of fitting...easy, difficult, requires an degree in automotive engineering?
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline am1w
I am sure it is easy to fit. Have not done it myself, but it's a straight swap of the knobs I think.
I'll put your name down anyway. :smiley:
Offline am1w
Updated list:-
Members interested in buying Ed 30 Manual Shifter - MFG Part #: 1K0 711 113 CM XPR:-
(1) AlanH
(2) am1w
(3) Exonian
(4) Gizzywizzy
(5) GolfTi
Members interested in Ed 30 DSG Shifter - MFG Part #: 1K2 713 203 AP XPR:-
(1) Neil GTi
(2) PenguinGTi
Any errors, please feel free to correct.
« Last Edit: 18 May 2010, 20:31 by am1w »
Offline AlanH
OK thanks. I have a horrible feeling the swap involves removing the gaiter, prising off tiny pieces of fragile plastic, sourcing a Torx driver from Taiwan, lifting out the engine...well, you get the idea! Would appreciate some reassurance that the job is both simple and straightforward.
Shove something flat underneath the front of the plastic surround that goes around the gaitor and shiny trim and gently lift it from the front. Either a trim removal tool or expired credit card is useful if you don't have steel finger nails.
Peel gaitor upwards to reveal big metal clip. Cut metal clip and lift knob and gaitor off.
Slide new knob onto shaft (fnarr fnarr) and clip up the metal clip (or better still use a hose clip that can be unscrewed, costs about 50p from B&Q or wherever) then once it's nice and tight over the shaft (fnarr fnarr) slide the gaitor and plastic trim into place and clip it into the centre console.
Get some elastoplast for your cuts and then return to admire your handywork.
Go for a drive.
Offline am1w
Go for a drive.
O fcuk! Just for a knob change?
I remember the days when you just had to screw one off and screw the other one on. :rolleyes:
Offline AlanH
But on a brighter note - no mention of engine removal  :grin: Nothing's ever easy on a VW.
Offline p3eps
I got my ED30 one off in about 2 minutes!
Stick your HAND in the leather gaitor, and grab the plastic infront of the gear shifter through the gaitor, and lift.  It just pops off.
The only tool you require is a meaty set of cutters to remove the metal clip.  Its pretty strong and takes something solid to cut through it.
I really went for it, as I was taking it out of my written off car in a hurry - but even then, I did no damage to it.
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline am1w
It pays to be butch sometimes which counts me out! :grin:
You R owners are the answer to a maiden's prayers! :laugh:
