Author Topic: Anything else worthwhile coding with VAG.com on a MkVI?  (Read 255707 times)
Offline The Doc
  • E63s Estate - Vito Sport
Re: Anything else worthwhile coding with VAG.com on a MkVI?
« Reply #60 on: 06 December 2010, 22:48 »
So guys, tell me more about changing the colour scheme of your RNS's?
Offline p3asa
« Reply #61 on: 08 December 2010, 10:04 »
Byte 7,  Bit 4/5 gives you the option of highline, sportline & premium.
Here is the choice of colour schemes
http://picasaweb.google.com/sportline155/RNS510Mod09#
Offline am1w
« Reply #62 on: 12 December 2010, 21:57 »
Good one p3!
Offline The Doc
« Reply #63 on: 13 December 2010, 12:05 »
OK thanks, am I missing something here, how do you actually choose the scheme you require?
Offline p3asa
« Reply #64 on: 13 December 2010, 14:53 »
Yeah you are  :grin:
In the picture above (which is VAG.COM) at BIT 4 - 5 where it has a drop down box saying "20 Display Variant" you can change the colour scheme to premium, sportline or highline.
Offline The Doc
« Reply #65 on: 17 December 2010, 18:08 »
OK, so they are pre-set, I cant have them all red for example?
Offline p3asa
« Reply #66 on: 18 December 2010, 17:47 »
No they are pre-set.
There are 3 themes and you can only have one theme at a time. The link I posted to Picasso shows what colours are in each theme.
Offline The Doc
« Reply #67 on: 18 December 2010, 18:38 »
Many thanks :-)
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #68 on: 19 December 2010, 18:56 »
I'd be looking to get my car coded for the alarm chirp & auto closing of windows/sunroof.
And the perma xenons are still anoyying me a bit. Do you think the dealer would be able to sort this for me?
The xenons can be turned off i just did mine. http://www.golfgtiforum.co.uk/index.php?topic=149385.80
But you need to find someone with Vagcom(VCDS) as dealers don't want to do it as they see it as a saftey item.  :sad:
Current Garage:
35+ years of GTI ownership.
Offline lowdown
« Reply #69 on: 22 December 2010, 18:26 »
I've got a loan of a VAG.COM cable so need to return it and wondered if there was anything worthwhile I should code while I still have the lead?
What I've done so far is:
Rear view camera re-coded
Buttons on MFSW
Nav directions on MFD (awesome feature)
Audio now back on MFD
Alarm chirp when locking doors
Changed colour of RNS510
Emergency brake warning (although couldn't get it to work no matter how hard I slammed the brakes on. Maybe not a UK setting?)
Auto Closing Windows via Rain Light Sensor
Voice control (although not installed the mic yet)
What does the rear view camera recode do?
