Author Topic: misfire on start up  (Read 7430 times)
Offline gti69
Re:misfire on start up
« Reply #10 on: 08 August 2003, 15:44 »
20 degrees is quite a way out, I'm suprised it even started at all.
Its a good point though, ignition timing can effect starting.
It was 20 degrees advanced , the rolling road bloke said that it wouldn't have made too much difference to high revs, it would have just taken away the power from low revs. When he reset the timing it felt like a new car! The power is all through the rev range now ;)
Offline Sam Manning
« Reply #11 on: 11 August 2003, 12:02 »
All seems to be fine.....rotor arm and cap seem a little burnt so may get a new one... from GTI.com they all seem to think its the head gasket...may take the plugs out to see if I can see a clean bore? Anyone had a head gasket blow on them before? My cam cover nut look truely rusted on!! Water loss i think was due to the seal in the cap not being in the correct position!!
« Last Edit: 11 August 2003, 12:03 by Sam Manning »
Offline Dean
« Reply #12 on: 11 August 2003, 23:09 »
I have just replaced my HT leads, dizzy cap, plugs and rotor arm, and this has not cleared my problem.
My car starts great then after about a secound runs like sh!t for 3 or 4  seconds and then brilliantly, but I believe I have a leaking valve or injector, my golf is an 86 GTi, with the K-jet engine, I would expect the injectors or valves to be worn, as the poor old pensioner has 192K on the clock now. I might retire it at 200K.
It could be the timing as my car does pink a hell of a lot, running on un-leaded, but it does not run any better on LRP.
Regards.
Dean.
I am just a mere pawn in the great game of LIFE!
Offline modulater
« Reply #13 on: 12 August 2003, 01:04 »
I used to have a MK1 Scirocco Storm that had the same problem but for a longer duration, the injectors were leaking and if left for a couple of hours it would need to be left turning for about 15 seconds to start it, I assume to build up pressure in the system that has subsided and also because it would be flooding and needed to clear itself out to fire. If the car was left for say 10 mins it would start up no worries first turn of the key.
Offline FranmaV4
« Reply #14 on: 13 August 2003, 11:35 »
I had this problem on my 16v KR.  I replace the injector 0-rings and it resolved the problem on startups.  Old rings shrink when cold and cause vacume leaks, but they expand when hot causing a good seal.
It depends if your 8v is K-jectronic or Digifant though.
F.
Offline Sam Manning
« Reply #15 on: 14 August 2003, 09:41 »
Mine is a Digifant? So is there O rings on the injectors? I have never had them off
