Author Topic: danny's mk2 something happend OMG  (Read 24507 times)
Offline danny_p
Re: danny's mk2
« Reply #30 on: 21 June 2010, 10:45 »
Quote
then i pissed around for a bit hacking things up that you really shouldn't hack up with a gas axe.  see if any one spots it. then gave the golf a quick one wheel conversion
please explain
look at the sand hoopper for the wet blaster.  it was a 13kg propane bottel.   the 1 wheel conversion is golf getting wheeled around on wheel barrow
all the VW's have gone bar 1.
Offline danny_p
Re: danny's mk2
« Reply #31 on: 21 June 2010, 10:49 »
the 5.2 is aftermarket.
vw will ahve done a simalar ratio but the part number probably probaly starts with the three letters denoting it's made of unobtanium  vwm.  iirc for 020 boxes you want the FD out of a std rod change syncro box think thats about the lowest factory 020 fd there is iirc
VeeDubGTI16v
Re: danny's mk2
« Reply #32 on: 21 June 2010, 13:35 »
Ill be going 02a next, the best ive found is a 4.2 out of a passat 8v
Offline fecked_tt
  • 4wdftfw
Re: danny's mk2
« Reply #33 on: 21 June 2010, 15:17 »
it's probably at the bottom of the 'to be concerned with' list but i hope you're painting it the same colour!
a4 2.8 30v v6 quattro gets me vag
Offline Diamond Hell
  • Opinions я Us
Re: danny's mk2
« Reply #34 on: 21 June 2010, 16:04 »
BIG colour change last I heard.  :grin:
Offline danny_p
Re: danny's mk2
« Reply #35 on: 21 June 2010, 20:29 »
It's defantly haveing a colour change.   it's going to be a really bright gash colour to  :cool: purely so the cocks in porshes who have selective blindness have no choice but to see the VW behind them
Offline danny_p
Re: danny's mk2
« Reply #36 on: 28 June 2010, 13:35 »
got the EPAS working on the bench speed sensitive and everything  :smiley:   don't know if i like it
think the vauxhall EPAS motorised device might be somewhat lighter,    thinking about fitting vauxhall pas onto vw manual rack  now
Offline danny_p
Re: danny's mk2
« Reply #37 on: 28 December 2011, 20:21 »
OMG something has happed on my mk2
and have a working camera on my new phone,  pics on way
  • Opinions я Us
Re: danny's mk2
« Reply #38 on: 28 December 2011, 22:12 »
Offline danny_p
Re: danny's mk2
« Reply #39 on: 28 December 2011, 22:45 »
well the syncro has been adandoned outside for a while witout paint on it,    really shouldn't have done that as it's made a whole load more work for me,  but the workshop1 has been full of other peoples stuff mostly thingying plant equipment like this POS and inbetween them a sick T25 has been in residence as well as countless nasty cars
but since last posting about it workshop1 has recived a few upgrades,  more lights tho still not enough ligts so more lights pending.   the ceiling that we put up the other year has been f**ked off so can get taller stuff in and a 2 post lift.  air supply has been upgraded from 15cfm via 40 cfm  to 170 CFM in total ( 130 cfm from a diesel compressor) theres also some new doors and stuff to fit and leccy supply needs upgradeing again.
anyway  after pokeing the broken audi with sticks decided to have a go at doing something on the golf,  like makeing a start on blasting it.  have a littel shot blaster pritty much exactly the same a this one hanging about
problem with them is there not that usefull, parts wear out at silly speed suffer with cloging up and there a bit slow.  blasting isn't the nicest of jobs so something would have to be done about those issues as don't fancy been there all day doing it. so it got modifyed ( stage 4 infact ),   looks really pikey and crap , proably explained by the fact it is and was all built out of scrap except for the nozzel and the fittings on ether end of the blast pipe
orderd a 10mtr blast pipe for it as that old length of 1"1/4  hydralic hose is a bit short,   addition of the oil /water separator  from an old under van hydrovane is a big feature it's remakably effective in stoping it clogging up  :smiley:
so tested it on a door, this door was black
made a start on the shell than ran out of grit, so will be haveing a ton of ground glass rock up at some point soon hopefully.
« Last Edit: 28 December 2011, 22:47 by danny_p »
