Poll
Coolant leak, replace O ring or Housing ??????
Replace O ring
0 (0%)
Replace Housing
0 (0%)
Total Members Voted: 0
Author Topic: MK5 thermostat housing  (Read 4450 times)
Offline Robin G
« on: 04 May 2010, 22:30 »
Hi Everyone,
I have just joined this forum, I was looking for some advise!!
I have just purchased a Golf mk5 05 plate, having moved on from the mk4. I have found that i have a coolant leak, look like its from the thermostat housing/O ring area. looking back on the history it has been replaced before !. Could the O ring be replaced or is it worth while changing the housing..... Any advise would be greatfully received. Also advise on anything about the MK5 at all... Thanks
Offline topher
  • Administrator
  • fully functioning
Re: MK5 thermostat housing
« Reply #1 on: 05 May 2010, 00:03 »
You won't know if the housing needs to replaced until you can remove and inspect it unfortunately. By that point it's a bit late if all you've bought is a replacement o-ring. If you're attempting this job yourself you should either be a mechanic or very brave/confident :grin: I've only done it once myself and can understand why VW charge silly money to do it!
Offline Robin G
« Reply #2 on: 28 May 2010, 15:23 »
Thaks for the reply, I have now got it into a garage now to see whats what! Purchased new thermostat housing only £23 so it was worth the money to replace it after the car has been stripped to get access to it........ time will tell !
