Author Topic: BBM MK2 - Daily goes in for another small resto. NOW FINISHED (sort of)  (Read 162832 times)
Offline Mr Blue
Thanks dubsport. A few high spec mk2's are popping up but you know where you saw it first. ;)
Sean it was a home made kit but needs to be under strict control (safety and mixture) or it wont plate. Id just hand them to a plater next time. Save the headache  :smiley:
If you do want to diy you need a voltage regulator, zinc chloride and ammonia chloride but the mixture has to be perfect. Ball ache
« Last Edit: 28 July 2014, 22:57 by Mr Blue »
Offline VR6_Wherry
It's things like this that make me want to buy a Mk2! This one of, if not the nicest Mk2 you will find!
The awards prove it! :cool:
Offline Mr Blue
Thanks Wherry.
Slow progress but this is a time consuming task based around a busy life.
More plating. Getting the hang of this
Managed to plate the tentioner spring. Chore!
Big valve head to fit. Might as well do it properly while its out :)
Offline Organisys
  • Old and Slow...
Sweet. Not tempted to do th 16v BBM conversion?
 :cool:
Offline Waspy
That engine. Looks, so good.
