Author Topic: CAI's  (Read 1148 times)
Offline emery1990
CAI's
« on: 27 April 2010, 19:32 »
Looking at my cold air intake i cant help but think that it looks too small? I can see its been cut on the front side. Has anyone else increased or bought up any piping near it get nice cold air?
Offline Neo Badness
  • Feet are for pedals
Re: CAI's
« Reply #1 on: 27 April 2010, 19:41 »
Have you considered one of these....?
http://cgi.ebay.co.uk/Electric-Intake-Turbo-Supercharger-All-Cars-Trucks-HP-/150436530685?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2306b749fd
Some more info, car, engine even a picture etc might help you get a sensible answer :wink:
Offline emery1990
Re: CAI's
« Reply #2 on: 27 April 2010, 20:41 »
I had one of them on my old car saved me 3 milers per gallon with added HP!
ermm fair enough, am i wrong to presume there mostly the same then, or did different models have different airboxes?
Heres my engine :D
You cant see the main bit im about, ill take a pic of that if needed, but youll what bit im on about anyway.!
Offline Neo Badness
Re: CAI's
« Reply #3 on: 28 April 2010, 22:33 »
Well saying I have an E reg mk2 valver running Kjet is better than the rather obscure acronym of CAI's, not everyone know's you mean Cold Air Intakes.
You can buy them or make your own out of tumble dryer tubing but remember that the air/fuel mixture will be changed if you're adding a whole load of extra air by cutting up the air box so you may need to compensate for this.
General route is to fit K&N panel filter, take out the plastic cone in the inner arch, and if you must, drill the airbox.
Only do this on the wing side of the airbox as it defeats the purpose if you let warm air from the engine bay in.
If you want more DIY then you could always knife edge/ port your Throttle Body, that should sharpen up your throttle response a bit.
Offline emery1990
Re: CAI's
« Reply #4 on: 28 April 2010, 22:57 »
Ok cheers. i did have kn filter in there which i think my mechanic took out and swapped with a crappy one, ill have to check this. oh right ok, the hole just seemed really small and sucking in hot air, ill work on something.
