Author Topic: Richard Lloyd Racing MK1 - Updating Broken Pics From Page 1 And Adding New Works  (Read 928772 times)
Offline SoundillusioN
Re: MK1 Black From The Dead (MOT Stuff & Timing p90)
« Reply #900 on: 14 February 2011, 11:50 »
I guess it is running non hyd tappets, if so you might need them checking and adjusting.
Yeah i'm almost certain it's solids as I believe Hydro's were used from 1985 onwards so would only be found on later Cabbys and Digi 8v MK2s.  Someone please tell me I'm right before I buy tools I don't need!
Looking good! Good luck with the MOT!
Cheers bud.
« Reply #901 on: 14 February 2011, 11:54 »
Remove the oil filler cap and you will soon see what you fitted.
« Reply #902 on: 14 February 2011, 12:14 »
I've had the cam cover off many times on all my MK1s... With the cam in place mine looks the same as hydro's that i've seen.  Whats tha big difference looks wise?
« Reply #903 on: 14 February 2011, 12:16 »
Do you have 5 cam bearing caps or 4 or look at the follower and see if you can see the shim in the top.
Offline richandhazel
« Reply #904 on: 14 February 2011, 12:48 »
I'm not sure that I would be able to tell the difference between a shim or a hydraulic lifter, just by looking through the oil filler, but I do know that the hydraulic lifters had a label on the rocker cover.......I suppose that is long gone.
The DX engine that was originally in mine was shims but the replacement engine is hydraulic. Assuming you have the original head/block combo you should be able to tell from the engine code but I have my suspicions that yours aren't very original!
« Reply #905 on: 14 February 2011, 13:09 »
Hmmmmm,  I do remember the rule about 4 or 5 bearing caps, never remember which is which, I think it's 5 for solids and 4 for hydro, in my mind i'm sure mine has 5... but would need to open it up again to be sure.  You defo can't tell through the oil cap hole and to be fair, forgetting the amount of bearing caps you can't really tell by just looking either, I just looked at pics of later 8v heads and what the cam strikes looks pretty much the same.
IIRC VW made Hydro 8v heads from 1985, the last time my car saw Richard Lloyd was in 1985!!! (by this year they were known as GTI Engineering). So there could be a chance that the head was updated to hydro..  It's a confusing car at times as it was badged up as both Richard Lloyd Racing and GTI Engineering.
All the paperwork for this has gone  :sad: (house burglary)  :angry:  All that remains is the GTI Engineering plaque that shows the engine number, valve clearances, fuel mixture etc.  I know that this car has had two engine numbers, the first from the RLR spec when new, the second when the car had more work done in 1985.
As far as VW engine codes go, it is possible to have DX coded engines with either solid lifters or Hydro, solid hydro up to 1985.... I think.
« Reply #906 on: 14 February 2011, 13:18 »
I would say that if the GTI Engineering plaque shows the valve clearances then you have a solid tappet head.
« Reply #907 on: 14 February 2011, 13:29 »
Very Good Point! :afro:
You can tell i've been out of the scene for a few years!
« Reply #908 on: 14 February 2011, 15:51 »
Spot on :wink:
Offline VR6_Wherry
« Reply #909 on: 14 February 2011, 16:02 »
Got to say good work here Shaun, not long now till you can take her back on the road (albeit some what slowly and cautiously)  :grin:
