Author Topic: Richard Lloyd Racing MK1 - Updating Broken Pics From Page 1 And Adding New Works  (Read 929597 times)
Offline lemski
  • 16v
Re: MK1 Black From The Dead (Tweaks, Changes and Pics P84)
« Reply #860 on: 29 January 2011, 18:06 »
Its 25 int it with them? I need to look at cheaper insurance
Offline shepgti
« Reply #861 on: 29 January 2011, 18:07 »
bugger :angry:
Offline SoundillusioN
« Reply #862 on: 31 January 2011, 09:22 »
Managed to attack my last couple of gremlins bit not fixed them....  Can't get any power through the horn wiring!...
Eventually found the plug for the Brake Fluid Level Sensor.  Of course it does't fit as the car doesn't have the mk1 braking system and I replaced all the looms so was looking for the worng plug for a while...  Not sure what car the fluid reservoir cap is from as it wants two seperate blade connections rather than a single plug.. eirther way I have sorted it and wired it up and the warning light is still on!.. tested switch in the cap... I think its fooked... need a new one.
Offline VR6_Wherry
« Reply #863 on: 31 January 2011, 10:01 »
Unlucky there Shaun, i'm sure you will have it sorted in no time!
It's these little things that can really get to you!  :angry:
« Reply #864 on: 31 January 2011, 10:08 »
  I know... was doing my head in.  I'm trying to figure out the origin of the cap as it doesn't have the socket for the sensor plug, just a spade connection either side....  whats yours like?
Offline Martz
« Reply #865 on: 02 February 2011, 21:58 »
Sounds like you have been a busy man mate. Looking forward to seeing this at a few shows this year! :cool:
« Reply #866 on: 04 February 2011, 10:58 »
Spending more time on stupid little faults now than I have with anything else!
Cr@ppy pictureless update
Had trouble trying to use the exisiting horn wiring as I cannot get a positve test through the wires under the engine bay.  Tested the steering wheel switch, that's fine, tested the sender wire to the fuse box with earh on the boss, passed. But when I put the testers earth on the car body and the positive to the horn switch sender wire, nothing.  After lots of head scratching it turns out the steering column and rack is not earthed so will not close a circuit.  Had a peek down the back of engine bay and I spotted that earth point 16 (rack to body) is broken.. Hope to sort this at the weekend!
After a few moments with the engine running, the Handbrake/Fluid Warning Light would come on and stay on.... I have now found the plug for the brake fluid level sensor (was wedged under the airbox),   I had to chop the plug off the loom and make new individual connections to use it. The cap is not the orginal as the car has a mk2 16v servo etc.. However the cap isn't off a MK2 and have no idea what it's from!
I have tested the fluid cap sensor and it appears to be switched on all the time, so will need to see if I can fix or replace.
My other problem is that I cannot for the life of me find where the handbrake switch wire is supposed to go.  Having a connector at the end of the wire suggests that it shares a connection with a low fluid level sensor wire away from the fuse box, I cannot see any spare connections. I checked the following pin locations at the back of the fuse box to try and trace somewhere to stick it.
C/12 - brake fluid switch
B/1 and A/15 - brake fluid/handbrake warning switch
E/13 - handbrake warning switch
In my new looms there are no wires in the above pin locations!  WTF!? Looks like there never was.
Resorted to plan b, removed instrument panels and located plug for the warning light, found the correct earth wire and spliced the handbrake switch to the plug, did a continuity test and lifted the handbrake, result.  however, when I put the battery back on, I heard a fuse pop.. now obviously the switch does nothing again.
 :huh:
MK1 Black From The Dead (Project Thread Now In Line p87)
« Reply #867 on: 05 February 2011, 04:22 »
MK1 Project Page in line with this thread now.... Whole project in 9 pages. Due to chat removal there may be the odd sentence that won't make sense now but... meh...  :cool:
Click
« Last Edit: 05 February 2011, 04:41 by SoundillusioN »
MK1 Black From The Dead (Big List Update - Crunch Time p87)
« Reply #868 on: 08 February 2011, 20:06 »
Well it looks like the growing list is finally slowing down for now, updated this to plan my last weekend bash at it!... (please don't fecking rain!)
To Source
Air Filter
All wiring looms (Engine, Interior/Dash, Lights)
Rear Light cluster
Bonnet
Front Bumper
N/S Wing
Front Indicators
Front side light bulb holders (bodged for now)
Headlight bulb retaining clip Thanks Chris :afro:
Rear Lights
Front Seats
Gear Linkage Kit
MK2 16v 256mm Vented Grooved/Drilled Discs
MK2 16v Front Brake Pads
New rear drums & Shoes
New Handbrake cables
Wheel bearings x4
Exhaust Hangers
15" BBS RA (Sportlines) x4
Late MK1 cabby Twin light Grille
Battery
Coil
Coilovers
Front Suspension Top Mounts
Rear Suspension Top Mounts
New Fuel Filter
Door Lock Pin
Headlight Bulbs
Spotlight Bulbs
Rear Twin Filament Bulbs
Windscreen Scuttle Repair Panel
Windscreen Seal
Windscreen Wipers
Window Winders
Twin Tone Horns
Front Wipers
2x 195/45/r15 tyres
Shift Weight
Windscreen Washer Jet
Washer Jet pipes
Heater Matrix Valve
Upgraded headlight wiring and relays
New Alarm System  :lipsrsealed:
New Numberplates and Dealer Holders
To Do
Strip out interior
Remove all wiring
Paint engine bay
Strip and paint cam cover and cam belt cover
Fit Air Filter
Remove BBS body kit
Full Rust Hunt and repair
Strip inner wings, paint/waxoyl
Strip Sills and Seams Paint/Waxoyl
Rewire car
Make and fit high power headlight/spots loom with relays
Fix Fuel gauge sender
Fault find MFA and fix if possible
No instrument cluster lights, fix
Remove and replace all gear linkages
Fit shift weight
Replace radiator
Clean out cooling system, fill with X Stream G30
Multiple engine flushes, new oil filter and fill with semi-synthetic
Fit later style cabby grille
Fit new bumper
Fit new 10 LED front indicators
Fit horns In progress
Refurb wheels
Fit new tyres
Fit new wheels
Replace rear drums pads and wheel bearings Bearings done, brakes postponed
Service Corrado Front Callipers
Replace front discs vented drilled/grooved 256mm and pads
Fix boot leak
Replace rear lights
Fit coilovers
Fit rear lights
Sound proof interior
Wash carpets and refit
Fit Seats
Fit window winders
Fit Front Wipers
Remove windscreen
Repair leak behind window rubber with new scuttle panel and seal
Prep and paint interior
Refurbish new wing
Prep and paint BBS body kit (Satin Black)
Prep and paint body and panels (Satin Black) In Progress
Refit BBS body kit
Seal Exhaust and replace hangers
Fix Brake Fluid/Handbrake Warning Issue
Fit Alarm System
Camber and wheel alignment etc
Tune Engine!!!!  :evil:
MOT  :shocked:
« Last Edit: 08 February 2011, 20:09 by SoundillusioN »
Offline Martz
Re: MK1 Black From The Dead (Big List Update - Crunch Time p87)
« Reply #869 on: 08 February 2011, 20:38 »
Good work so far Shaun. :cool:
