Author Topic: Richard Lloyd Racing MK1 - Updating Broken Pics From Page 1 And Adding New Works  (Read 929488 times)
Offline richandhazel
Re: SoundillusioN - MK1 Black From The Dead (Mahoosive Update Time)
« Reply #280 on: 14 September 2010, 11:49 »
I need a few different ones for my dash. I'm thinking do it different and add in some more so its brighter. We'll see.
Sorry I meant pics when you get them and they're fitted.
Yep, good idea, I'll do some before and after pics :wink:
Offline SoundillusioN
« Reply #281 on: 14 September 2010, 11:50 »
Well ive not planned to do them yet. was advising Rich.  it'll be something i'll do when the cars on the road..  Yeah I have added more than starard beforein my old previous mk1, had some extra drilled in the top of the cluster shining red on to the front of the dials so i didnt have to mess about with the green filters.  all depends on what look you're after.
SoundillusioN - MK1 Black From The Dead (Whats Left)
« Reply #282 on: 15 September 2010, 00:08 »
For my benefit really, :smiley:
Just bought:
2x Admiral 712s 195/45/R15
Aero Wipers
MK3 Golf Shift Weight
Exhaust Hangers
Desperate stuff left to buy for the MOT is a washer jet and pipework, a horn, headlight bulb retaining clip (HELP!), sidelight bulb holders and a couple of bulbs! i think thats it!
To Source
Air Filter
All wiring looms (Engine, Interior/Dash, Lights)
Rear Light cluster
Bonnet
Front Bumper
N/S Wing
Front Indicators
Front side light bulb holders
Headlight bulb retaining clip
Rear Lights
Front Seats
Gear Linkage Kit
MK2 16v 256mm Vented Grooved/Drilled Discs
MK2 16v Front Brake Pads
New rear drums & Shoes
New Handbrake cables
Wheel bearings x4
Exhaust Hangers
15" BBS RA (Sportlines) x4
Late MK1 cabby Twin light Grille
Battery
Coil
Coilovers
Front Suspension Top Mounts
Rear Suspension Top Mounts
New Fuel Filter
Door Lock Pin
Headlight Bulbs
Spotlight Bulbs
Rear Twin Filament Bulbs
Windscreen Scuttle Repair Panel
Windscreen Seal
Windscreen Wipers
Window Winders
Twin Tone Horns
Front Wipers
2x 195/45/r15 tyres
Shift Weight
Windscreen Washer Jet
Washer Jet pipe
Heater Matrix Valve
To Do
Strip out interior
Remove all wiring
Paint engine bay
Strip and paint cam cover and cam belt cover
Remove BBS body kit
Full Rust Hunt and repair (in progress)
Strip inner wings, paint/waxoyl (fronts done)
Strip Sills and Seams Paint/Waxoyl (in progress)
Rewire car
Make and fit high power headlight/spots loom with relays
Fix Fuel gauge sender
Fault find MFA and fix if possible
No instrument cluster lights, fix
Remove and replace all gear linkages
Fit shift weight
Replace radiator
Clean out cooling system, fill with X Stream G30
Multiple engine flushes, new oil filter and fill with semi-synthetic
Fit later style cabby grille
Fit new bumper
Fit new 10 LED front indicators
Fit horns
Refurb wheels
Fit new tyres
Fit new wheels
Replace rear drums pads and wheel bearings Bearings done, brakes postponed
Service Corrado Front Callipers
Replace front discs vented drilled/grooved 256mm and pads
Fix boot leak
Replace rear lights
Fit coilovers
Fit rear lights
Prep and paint and interior
Sound proof interior
Wash carpets and refit
Fit Seats
Fit window winders
Fit Front Wipers
Remove windscreen
Repair leak behind window rubber with new scuttle panel and seal
Refurbish new wing
Prep and paint BBS body kit (Satin Black)
Prep and paint body and panels (Satin Black)
Refit BBS body kit
Seal Exhaust and replace hangers
Camber and wheel alignment etc
Engine Tune!
« Last Edit: 15 September 2010, 01:45 by SoundillusioN »
Offline dom
  • Back in a Mk4
Re: SoundillusioN - MK1 Black From The Dead (Whats Left)
« Reply #283 on: 15 September 2010, 17:29 »
Thats one hell of a list  :shocked:
At least the majority of it is done :afro: :smiley:
Do you have a date for the MOT yet??
Offline rcsammy
« Reply #284 on: 15 September 2010, 17:32 »
its gonna be like a brand new car by the time your done.... well better than new infact
« Reply #285 on: 15 September 2010, 21:09 »
Yeah I posted a list a while back, its grown a little recently and i think theres a little more, done lots of little jobs but thought it would be a bit sad listing all of it!
Yeah ive managed to cross quite a bit off now.. just hope nothing else pops up!..
It was supposed to be road going by my birthday which is next week!  :laugh:
Run out of cash so need to wait till pay day, all being well i will be booking it at the end of the month!............
....and then get laughed at as everything thats not listed here is fooked!  :laugh:
and will hopefully look it when its repainted!
Re: SoundillusioN - MK1 Black From The Dead (Foggy)
« Reply #286 on: 15 September 2010, 23:22 »
Boring little update but was pi55ing it down!  again.... :sad:
The Vauxhall Frontera fog arrived, opened up my damaged fog to find a sealed unit inside.. I knew I had to split the glass off somehow and was going to ask how!
opened up the frontera fog and found the same shizzle as mine inside!  The reason I was suprised was because of the way they are both put together, looked like the glass was clamped down from the front and the back of the frontera one looked like it was complete with nothing else inside.
Need to clean up my fogs now and put them back together, may have to get another frontera fog as one looks loads fresher than the other now!
« Reply #287 on: 17 September 2010, 09:22 »
Good find that, one to remember :wink:
Changed my LCD for the MAF and installed the LED's.........both failed :angry:
Not sure why the LCD doesn't work, can only assume that it is slightly different, random segments are working.
The LED's aren't making contact with the membrane, seem to be a little smaller.
« Reply #288 on: 17 September 2010, 10:02 »
Hmmm, shame about the LCD but dont understand why the LEDs dont make contact!??... how much does it miss by... i'll have to get some now from a different supplier and see if i have the same problem as when i bought some for my old white tin top they were just right?
« Reply #289 on: 17 September 2010, 11:01 »
Here you go:-
