Author Topic: Richard Lloyd Racing MK1 - Updating Broken Pics From Page 1 And Adding New Works  (Read 929502 times)
Offline SoundillusioN
.. you've got no excuse, you've got a garage!... what have you got to do to yours!?
I have 2 garages so i have double the non excuse  :grin:
To do? Back panel, full respay as not happy with it as i can see the repair and ive never been 100% happy with the re-spray it got, new plastic arches, spolier and bumpers. Maybe even replace the front panel as its never looked straight since i bought the car and its always bugged me, New bottom arms and re-bush everything all round, new brakes, fit the new oem suspension i have had sitting about a while. (It has jamex on it and i find it shakes the shell to bits) Set the injection system up right, fix the MFA mpg thats gone faulty, and many other bits and peaces. The golfs on the list after i re-assemble one of my other projects so i cna get the mk1 in that garage.
What repair was that then?... back panel, is it the lower half thats gone at the corners?, mines shot in both corners, have a replacement that I need to get done but I can't weld.  I'll be intrested to see how much mine shakes me to bits compared to the Bilstein/Eibachs... they weren't too bad. i'm guessing your other project isnt a dub then?
SoundillusioN - MK1 Black From The Dead (THE BIG LISTS)
« Reply #191 on: 10 August 2010, 13:38 »
Have to start getting organised so for my benifit made the following lists.... If anyone can help source anything i'm missing though, that would be great!  :smiley:
To Source
All wiring looms (Engine, Interior/Dash, Lights)
Bonnet
Front Bumper
N/S Wing
Front Indicators
Front side light bulb holders
Headlight bulb retaining clip
Rear Lights
Front Seats
Gear Linkage Kit
MK2 16v 256mm Vented Grooved/Drilled Discs
MK2 16v Front Brake Pads
New rear drums & Shoes
New Handbrake cables
Wheel bearings x4
15" BBS RA (Sportlines) x4
Late MK1 cabby Twin light Grille
Battery
Coil
Coilovers
Front Suspension Top Mounts
Rear Suspension Top Mounts
New Fuel Filter
Door Lock Pin
Headlight Bulbs
Spotlight Bulbs
Rear Twin Filament Bulbs
Windscreen Scuttle Repair Panel (hopfully picking one up on Thursday!)
Windscreen Seal
Window Winders
Twin Tone Horns
Front Wipers
To Do
Strip out interior
Remove all wiring
Paint engine bay
Strip and paint cam cover and cam belt cover
Remove BBS body kit
Full Rust Hunt and repair (in progress)
Strip inner wings, paint/waxoyl (fronts done)
Strip Sills and Seams Paint/Waxoyl (in progress)
Rewire car
Make and fit high power headlight/spots loom with relays
Fix Fuel gauge sender
Fault find MFA and fix if possible
No instrument cluster lights, fix
Remove and replace all gear linkages (done but needs to be aligned!)
Replace radiator
Clean out cooling system, fill with X Stream G30
Multiple engine flushes, new oil filter and fill with semi-synthetic
Fit later style cabby grille
Fit new bumper
Fit new 10 LED front indicators
Fit horns
Refurb wheels
Fit new tyres
Fit new wheels
Remove braking system
Replace rear drums pads and wheel bearings
Service Corrado Front Callipers
Replace front discs vented drilled/grooved 256mm and pads
Fix boot leak
Replace rear lights
Fit coilovers
Prep and paint and interior
Sound proof interior
Wash carpets and refit
Fit Seats
Fit window winders
Fit Front Wipers
Remove windscreen
Repair leak behind window rubber with new scuttle panel
Prep and paint BBS body kit (Satin Black)
Prep and paint body and panels (Satin Black)
Theres bound to be more... I need to get the vitals done and MOT'd by 21st September!!!  :embarassed:
« Last Edit: 10 August 2010, 16:23 by SoundillusioN »
Re: SoundillusioN - MK1 Black From The Dead (THE BIG LISTS)
« Reply #192 on: 11 August 2010, 00:00 »
Good luck with getting it finished
« Reply #193 on: 11 August 2010, 00:01 »
Is that sarcasm!  :laugh:
« Reply #194 on: 11 August 2010, 00:02 »
Nope  :smiley: if you were closer I would help.
« Reply #195 on: 11 August 2010, 00:04 »
Aww thanks!.... could do with it!.. i'll go get a trailer.  :grin:
« Reply #196 on: 11 August 2010, 23:49 »
So I moved the car tonight and noticed it looked a bit on the pi55....  gave the car a bounce in each corner and noticed the front was perfect and the rear was bouncy as fook!.... turns out that the lack of weight and drop at the rear means she's still resting on the helper springs, theres an inch to go before they will compress fully!!!, i have no choice to drop it quite a bit more... not sure if thats good or bad as i was only planning to go a little lower for now.
Offline dom
  • Back in a Mk4
« Reply #197 on: 12 August 2010, 12:43 »
Bloody hell, i've been on holiday for a week and look what's happened  :shocked:
Great progress, keep the updates coming :afro:
Nothing like a fast approaching deadline to give you a kick up the arse  :grin:
« Reply #198 on: 12 August 2010, 13:11 »
cheers, well i hadnt done anything in ages so thought id better start pushing!.... run out of money though for this month!  :sad:
Offline Malty
« Reply #199 on: 16 August 2010, 12:11 »
Alright Shuan,
So ive finally dragged myself on here! the cars looking good! saying that it looks better in real life :)
Malty
