Author Topic: rwd conversion  (Read 16822 times)
Offline Shady Pioneer
  • graphic designer.
Re: rwd conversion
« Reply #20 on: 18 May 2011, 14:16 »
Had to increase to 400% to read it! :grin:
If you quote it you can read it a lot easier. :afro:
Offline Len
Re: rwd conversion
« Reply #21 on: 18 May 2011, 14:54 »
Propshaft wont be a problem mate, you can get them made up quite easily!
Main problem will be getting the drive back around 90 degrees!
Might be easier to turn the engine around and find a gearbox that fits!
Basically if you really want to do something, it can be done!
www.sas.org.uk
www.the-ace.org.uk
Offline sportsman
Re: rwd conversion
« Reply #22 on: 18 May 2011, 15:07 »
what do you mean getting ther drive back around 90 degrees
Offline trog_nfs
Re: rwd conversion
« Reply #23 on: 18 May 2011, 15:37 »
Like the kit car boys do with zetec engines and Mx75 (i think) gear boxes out of the sierra?
Re: rwd conversion
« Reply #24 on: 18 May 2011, 15:57 »
It is a daft idea and any major changes to the shell will lead to hassle with the dvla in getting the car on the road.
Offline Jack3559
Re: rwd conversion
« Reply #25 on: 18 May 2011, 15:57 »
Buy an old BMW if you want cheap RWD.
Offline Len
Re: rwd conversion
« Reply #26 on: 18 May 2011, 16:10 »
Like a TVR V8 engined Golf then! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline Len
Re: rwd conversion
« Reply #27 on: 18 May 2011, 16:12 »
Well a Golf engine is transverse, that means its axis is across the car.
If you want to drive the rear wheels via a propshaft the drive which normally goes across the car will need to be turned 90 degress to go to a back axle.
Or you can turn the engine 90 degrees!
www.sas.org.uk
www.the-ace.org.uk
Re: rwd conversion
« Reply #28 on: 18 May 2011, 16:22 »
That was then, the rules have changed, any changes to a shell means the car will need an iva test, if you don't believe me speak to DH.
Offline trog_nfs
Re: rwd conversion
« Reply #29 on: 18 May 2011, 16:39 »
You don't see shell changes any more. The only ones I've seen recently are big companies doing cosworth swaps in fiesta's and focus's to show off their skills.
