Author Topic: Subframes and lower arms question - SEAT Cordoba into MK2 conversion  (Read 4981 times)
Offline Horney
Sounds like you're cracking on with it Mark. When it comes to getting the blighter in the MKII give me a shout and I'll lend you my hands again.
nick
Offline Skid
How far down the rabbit hole are you going?
ha ha - a pun on the Yankee golf naming?
As much as I wanted a 'VW' golf upgrade, I've fallen headlong and it's becoming a mix n match upgrade, but what the hell, I'll get something better and for a bit more money, a lot more car. Or so the plan goes anyway.
So how far down the hole? I've sourced a rebuilt, ported and heat treated M62 eaton with a fixed wheel (no clutch), am having the head ported for high flow, a cam change to aid supercharging, (still being researched), a cut and shut inlet manifold, add in megasquirt, ARP bolts and decompressing, then probably a TSR hybrid Mk2 ABF manifold, then it's been a proper exercise.
Chassis wise wishbones in process of welding reinforcement, maybe for the subframe too, then powder coating. Bearings, bushes, ball joints, cam belt, blah blah blah will all be renewed.
Strut bracing a sensible addition and eventually will get around to suspension, though some way off researching this yet.
Clutch will be sorted to cope, and finally a LSD will be considered depending on budget.
Aim is a very fast but tractable road car with an obscenely fat torque curve, not a dyno queen.
Aparently it's all in the girth of the curve, not the thin high peak  :wink:
Offline Skid
hi Nick,
yes if you don't mind I will take you up on this. So much easier with an extra pair of hands.
When time has allowed I've been researching and part locating. I'll basically get everything I can think of, lay it out airfix style on the floor so I'm happy I've got everything, then take the old golf off the road one weekend.
When this is stripped of mechanicals I'll take a few days to jet wash and clean the engine bay and make any paint and rust repairs required. I'll probably waxoil down the chassis rails too. Then it's a case of refit and replace.
The headaches are going to come after I think with understanding the new wiring requirements and plumbing the intercooler in without (hopefully) having to hack too much around.
That's the plan anyway. But as with all great plans.......... :wink:
