Author Topic: engine stalling after rocker cover gasket change  (Read 3180 times)
Offline mk1
Re: engine stalling after rocker cover gasket change
« Reply #10 on: 26 November 2004, 20:34 »
HI Blue.
There was a modified gasket available from VW, you had to replace the studs and the gasket was made of rubber. The new studs had a shoulder on them to stop over tightening and crushing the gasket. Cant find the part no at the mo, but worth speaking to the stealer if the oil leak is a problem.
Rain
« Reply #11 on: 26 November 2004, 20:44 »
by any chance are they little plastic washers?
they was already on mine i just replaced cause the oil was eating them up.
Blue MK2
« Reply #12 on: 27 November 2004, 12:16 »
thanx alot peeps. great help.
I had to change the studs to go with the gasket and this has stoped the leak.
Might be something worth remembering when changing one.
Blue
